Racepak IQ3 Dash Help
A friend just bought a car with the RacePak IQ3 dash. He is running at Road America this weekend and just wants to get it setup enough to look at lap times. He does not have the buttons installed yet, so my understanding is he needs to write the coordinates to a LAP file (which I have an example of), save it as a LSF file and write that file to the SD card. Assuming that is correct, does anyone have the coordinates to the start/finish line at RA? Or even better an LSF file I can write to the SD card?
It's pretty easy to hook up a cheap single button to set the start/finish line. Can do it in probably 10 minutes. I don't have access to my sd card so can't send a file.
get some buttons at radio shack... wiring should take three minutes. PITA to program the coordinates and then upload. you'll need the buttons anyway to scroll through the display windows, and to set your gear ratios, etc. It's even possible to wire to existing buttons in the car (mine was initially wired to my cruise control stalk, which was a very tidy solution when the car's interior was in a more "stock" configuration).
