HANS Racing Seat ?
What makes a racing seat HANS compatible? For example, if I look at the Recaro Profi XL versus the Sparco EVO versus the Sparco CORSA, they all look to have similar sized rear harness openings but only the Sparco EVO is listed as HANS compatible.
Sorry misread the question. I have the pro racer XL.
As mentioned above, The backrest is contoured to allow you to sit fully back. Also (not to get into a debate on head and neck restraints), the wings on the seat prevent my head from moving laterally-diagonally, which could be an issue with a Hans.
I was lucky enough to try the pro racer vs other recaro seats. If you sit in the others, with a Hans on, you can feel,the difference
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
There are some people who the way their body sits, cannot have a HANS on comfortably in some seats. Most have no issue whatsoever though.
What ends up happening is the HANS pushes their heads forward awkwardly. So you either need to bump the seat back or push the lower part of the driver forward.
Some of the aluminum seat companies make a marked step back of roughly 1" for those people too.
