Street / Track DIY: Alignment? Rotors?
Questions for the street/track DIY crew - does anyone do their own alignment when going from Street to Track and back again?
What about rotors? When you swap to track pads, are you also swapping rotors?
I have a 997 that I plan to track somewhere down the road, as the depreciation kicks in a bit more. I have some pretty cool suspension bits and I'd like to get RSS LCAs at some point. I'm curious about whether I'd be able to mark the settings for street and track and adjust myself, or is that crazy talk?
If I was to really set my car up for dual use - maybe 5 DE weekends/yr max - I would be fine with the following:
- pads change
- Rotors? I just did my first pads/rotors swap and it's not that big of a deal. I've heard that you shouldn't use the same rotors for street and track pads, but I'm not sure if that's overly conservative
- maybe a brake bleed or maybe I'd have a shop do that along with a tech inspection to make sure I haven't missed anything
- front seats swap for race seats w/harnesses
- roll bar in, then out, along with harnesses of course. I'm too tall to leave it in, plus I use the back seats for small kids, so might as well take seats out while messing with the roll bar
- wheels (tires) change
- in-car video like go-pro
- fire extinguisher in/out
- and then there's the alignment. I wouldn't so much mind getting one alignment for each track weekend, but I'd need two: one for the track setting and one back to street setting. That's my biggest sticking point.
I think I'm OK with 4-6 hours of prep, but I'd figure on getting that down to 3-4 as I get used to it.
Interested on thoughts from other dual-use DIY'ers. I know you're out there!
- pads change
Jack Olsen would have some good views on this, but when I still had a combo car I did none of the above. I just drove it on the street with the track stuff. If you do this more than 1-2 times per year, the swap back and forth will get really old IMO.
+1. Putting in a roll bar, properly mounted harnesses and seats in will cure you of the desire to ever do that again, or even remove it, in my experience.
I've also become quite adept at living with a 'track' alignment on the street (for what little driving I do in the real world). Then again, I barely drive anywhere in real life -- mostly to and from the track!
This is only a stopgap solution. If you're 997 is aging, you'll replace it with a Land Cruiser. You can daily drive the Land Cruiser and tow the track-prepped 997 with it on the weekends.
I know about the slippery slope and went from a street 911 cab (1990), "converted it" to dual use and then bought a dedicated track car - between 1999 and 2003. The 944 is now broke, taking up garage space, and I'm not sure I want to fix it. I'm very busy with kids and I'm lucky to get out once/twice per year. 5 DE events/yr is extremely optimistic. With that little of track time, it seems a bit silly to have a dedicated car.
So - if I dual-use my 997, I'd really want harnesses and they don't work with my sport adaptive seats. I can buy the GT2 seats or whatever for $6k+, or get some other solution, but putting the roll bar in and out will not be as easy with the seats in vs out. I know I need a roll bar if I have harnesses. I already have the HANS. If I gut the 944, I can use those Cobra seats and Shroth harnesses, plus some other bits.
I think the advice is good and I'd probably have to skip the alignments and go with a compromise setting. I'd skip the rotor swap and just do pads - thanks for that. I wasn't sure what everyone else was doing on that one.
I agree on the brake bleeds - seems like a good way to deal with the shop that does the tech inspection. That was my original thought.
As far as converting the 997 to a dedicated track car, that's not going to happen any time soon. Maybe in 7-10 years. I've been daily driving a 911 since 1999 and I'm not going to stop any time soon, and I'm not going to afford a 911 AND a dedicated track car unless I fix the 944 - which might still happen. We'll see...
This is not something I'm going to start doing right away, but it helps plan my mods. I was hoping for a reason to 'invest' in the LCAs, but I don't think I really need them.
Thanks again!
Jack
Thanks again!
Jack
If you're doing harnesses, you'll need a roll bar and race seats. Both can be easily swapped before a DE weekend. If you're on regular street tires, you won't need to change pads. If you go with a dedicated R-compount track wheel set-up, it's worth doing pads.
I knew the alignment was an oddball thought, but I had a mechanic once who told me he was marking the suspension bits for my alignment setting, so they know where it goes if it gets out of whack. So I figured I could get it marked in TWO places, one for the street and one for the track. But - it probably makes more sense to go with an aggressive street alignment and swap the tires on the rims 1/2 way thru their life.
Thanks for the input!
Addicted Specialist
With 5-6 weekends/year, you will soon find what is and is not a good tradeoff of your time/energy spent and what your reap as benefit.
For example, you know what to do WRT the rollbar: your height constraints made your decision. But other items are up to you.
For example, are you adept at alignment? And will you be comfortable with living with what settings you've created on the track (you might screw it up and hate the car's handling for the whole weekend).
Wheels are a gimme: easy and makes sense to swap. That said, I used to do so and eventually ended up selling the track set and simply mounted r-comps on the car all the time. That saves me time, expense, and one less thing "to do" ...which makes each event that much more enjoyable
Brakes are easy. With the wheels off, swapping street/track pads is a 3-minute affair and well worth it. Rotors? I wouldn't bother: no reward here, IMHO. No issue whatsoever with the differing pad compounds on the same rotor ...or at least none I've ever noticed on the two cars I've done so on. And brake bleeds: that's a duh-gotta-do task. It is only a few minutes with a Motive Power Bleeder, and the consequences of old fluid cooking on the track as your pedal drops to the floor is, let's just say, costly.
Bottom line is you add up all the stuff you do to prep the car for track, then de-prep for street, sum your time and energy, and then decide what your comfort level is.
Edward
Edward
