Schroth HANS-compatible 6 pt or Sparco HANS-compatible 6 pt ?
But with a Hans that has the little wings, no noticible difference but I prefer the 2" as it is easier to get the shoulder belts on just right in a quick driver change situation...
Not sure about the Sparco's, but we like the Schroth Profi belts in our LeMons car. With the pull-up adjustment on the lap belts, they are by far the best belts I've ever used for quickly tightening up. Greatly helped our pit stops.
I have a few different versions of Scroth, a TeamTech and a Sparco... the Scroth enduro belts are by far the easist to adjust...the hardware is unique to the particular model of the Scroth line. A bit more expensive, but WELL worth it for comfort and quickness of getting an adjustment that feels right...
http://www.apexperformance.net/prod-1850.htm
If you contact Clark at Apex, he offers a PCA discount and has great service!
I have found the same thing...the only time I have noticed a difference is when using an older Hans that did not have the little wings on it. The 3" belts would move more and would not stay put as well as the 2" belts.
So when not using Hans sometimes, the 2'' shoulder belts feel similar to 3'' belts when not using Hans?
Ive got Schroth Profi II in 3". If I recall, youve got a newer model Hans, presumably with the shoulder lips, so you dont need the Hans specific 2" shoulder straps. I'd go with 3" to keep it simple and versatile.
My only regret is not getting the pull up lap straps (I got the porsche specific belts, which arent reversible). Get the pull up capability.
Im very happy with Schroth. Probably a bit more expensive, but not meaningful over 5 years.
I have not got in a car and used a harness without a Hans since I got a Hans...
