Just installed 3.0 S2 engine Running on 3 cylinders Racing at Sebring Friday Help!
Thanks, I don't think that tool will work on a 16V, since the spring is buried in a hole. This one is supposed to work. Has anyone used it? http://www.fcpeuro.com/products/bmw-...r-kit-cta-2112
Been awhile since I worked on one.
That tool should work just fine.
Here is a pic of the factory tool.
Here is the culprit. I managed to create a "McGiver-like" spring compressor and install another valve spring pair. The replacement spring, from another S2 head has smaller windings, but is the same height. The inner spring appeared identical. The broken spring also has 2 red stripes on the upper couple of windings. Has anyone seen this before?
