Fire Supresssion System
I am looking to put a 5.0l (10lb) fire system in my car w/ 3 to 4 spray nozzles. I was wondering what many of you guys use? The SPA system and the ESS system both look nice but is there any downsides and are there better systems out there?
The SPA AFFF systems come in both electronic and mechanical. Electronic systems are powered by a battery power pack independent of the car and can be triggered either from inside the cockpit, or externally by a corner worker using the provided internal and external buttons. The mechanical systems utilize pull cables (provided) to be activated. Both come with 6 nozzles so you have a lot of flexibility as far as placement. Information on both can be found below. AFFF is not corrosive to electronics and wiring and the SPA bottles can be serviced and refilled in the event they are discharged, whether intentionally or accidentally.
http://www.ogracing.com/spa-fire-sys...fff-mechanical
http://www.ogracing.com/spa-fire-sys...-afff-electric
Kind regards,
Mark
Kind regards,
Mark
I have this one:
http://www.lifeline-fire.co.uk/motor...tr-electric-59
fortunately, it worked for me.
unfortunately, I had to find out.
Since 2009 SPA has been filling systems with an anti-freeze AFFF which is effective down to 0*F. SPA recommends removing the bottle from the car in cases where it may be subjected to sub zero temperatures.
If you have a bottle that was last serviced prior to 2009, you should have it serviced. We are an authorized service center for SPA fire bottles.
That is a scary photo!
Just keep in mind the water based systems need a bit more care than the Halon or FE-36 types.
Mark that is good to know that SPA is using an anti freeze. Do you know what they are using?
