Race Data Logger- Open Source
Basic Site Sponsor
Basic Site Sponsor
Received 3,293 Likes
Trivia test...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
The Penguin King
I built a Heathkit stereo receiver with my dad, and then later built a Hafler power amp. Still have the Hafler. So I guess I win the Old Nerd Trivia Contest.
Basic Site Sponsor
Basic Site Sponsor
Hey, Mike! I may still have a Hafler pre-amp with a moving coil phono cartridge input in my stash somewhere...
Sheesh, these kids...
Thanks Peter!
I am computer/programming savvy and a bit ok on the electronics side. I am not as car mechanically capable. What's throwing me off is that my understanding of both this system and most other DAQ is that they use ODB to get many of the inputs like throttle & brake position, speed, revs, etc. Since my 76 doesn't have that output, I'm curious if it's possible (but more complicated?) to get those inputs hooked up to DAQ some other way or if I'm just out of luck?
The Penguin King
Basic Site Sponsor
Basic Site Sponsor
Actually, most data systems until very recently (those built before pre-2009) obtained the inputs of the vehicle ONLY through installation of standalone sensors connected directly to the logger, so they could be used with ALL cars, including yours.
Most loggers above $1200 (AiM EVO4, MXL Pista, Race Technology DL1, RacePak IQ3, Race Keeper SE and HE, MoTeC ADL and SDL variants) still do that, so you're all set!
Where loggers have become less expensive and much easier to collect a variety of VEHICLE information, without installing additional sensors for throttle, steering and brakes, is the implementation by the manufacturers of various stability controls in their cars, mostly post 2006. These additional systems rely on sensors they install in their own cars, and these less expensive offerings like the AiM Solo DL and MoTeC CDL allow logging of the information collected by these sensors already installed. Often, access to this built in sensor information is through the OBD-II connector, but mostly its through the two-wire CAN Bus wiring between the ECU and the instrument cluster. This often eliminates the need to add additional sensors required on the earlier cars to gain access to that information.
Bottom line is the Autosport Labs device, the Race Technology DL1 and the AiM EVO4 (not necessarily in that order) are the best units for older cars (all under $1200) that will log not only driver inputs and measured forces and speed, as well as GPS track mapping and timing, but also allow for the additional analog (0-5V potentiometers, sensors) or digital switches (on/off switches like brake lights) inputs so you can track vehicle health and gain additional insight into what the driver is doing.
You are NOT hobbled by having an early car, just more work to equip it and set it up.
