HLT in-car video
I've been instructing for a couple of years and was trying to find a (relatively) inexpensive way to integrate video and telemetry data, but take the system along when I hop in a student's car too. Here's what I have so far:
Anybody else use the Optrix HD and find a decent place to mount it in car without a cage and/or in a way that can be moved easily from car to car?
If I can't use the CruiseCam headrest mount, I use an external camera (in this case a ReplayXD) with a clip-mount and integrate the video to your data later. This took a little experimentation to figure out but here's a relatively painless way to do it. You just need to know the visual reference for your start/end point in Laptimer. If it's a track, it's the start/finish line. I'm using an iMac, I imagine there's a similar path for Windows.)
Video with the OBD-II data in a MINI Cooper S.
Same track in my 996 daily driver without the OBD-II data.
(Let me know if the links are not working.)
- CruiseCam In-Car Headrest Camera Mount
- OptrixHD iPhone 4 case with wide-angle lens
- Dual XGPS150 Bluetooth external GPS
- PLX Devices KIWI Wifi OBD-II wireless interface
- Harry's Laptimer Pro software for iPhone
- Figure out what the format of your video file is first. If it is a format that the iPhone can understand natively, skip ahead to step #3.
- Convert your video to a format the iPhone will understand. In this case, convert the file from AVI to M4V using Quicktime export.
- Export your video to the iPhone. You can do this in several ways: load the file into your iTunes movie library then sync to the iPhone; attach and send to yourself via email and save from email on your iPhone; or iMessage it to your iPhone and save to the camera roll.
- Review the data your recorded in Laptimer and decide which lap you want to overlay with data. Laptimer overlays data one lap at a time.
- On your computer, find the runtime of the video when that lap ends.
- View the lap data in Laptimer.
- Select Edit.
- Select Add Video.
- Select the video you just uploaded to your iPhone.
- Set the end point of your lap based on the runtime noted above.
- Select the frame in the video matching the end of the timed lap. (Start/Finish line)
- Then select Overlay.
The additional captions over the video are interesting. I like the vMax and vMin in particular.
This has changed since I used it last.
Did you manually enter "Braking point for T5" in the Mini video, or is it something the app does?
The break point for turn 5 and exit for turn 9 came over in the SP Main download. They are used for sector times as well.
I thought about that, but I'm cheap and I was trying to make the most of stuff I already had laying about. Besides I want something to work in other cars besides my own. The PLX cable I was using with an OPD-II code reader app (sunk cost). The ReplayXD camera I've had for a couple of years but stopped using. I already had the iPhone 4, and the CruiseCam arm I bought on fleaBay for around $10 five years ago. So the only incremental costs were the Optrix case which is about $100, the GPS which I bought with Amex points, and HLT which is about $20.
