Its that time!! Castrol SRF ready to ship!!
Former Vendor
Now that the off season is here its time to start thinking about getting your car ready for the 2013 track season. This means removing, cleaning, inspecting and replacing parts on your beloved Racecar.
Dont forget about that brake fluid!! We are in stock and ready to ship the following brands:
Castrol SRF
![](http://i1012.photobucket.com/albums/af250/supremedk/srf.jpg)
CASTROL SRF Racing Brake Fluid is an ultra high performance product formulated specifically to satisfy the ever increasing stresses placed upon the braking systems used in international motorsport. The exceptional performance of Castrol SRF is due to a novel silicon ester technology pioneered by Castrol and unique to the extent that it has been granted patent-protection in numerous countries throughout the world.
Castrol SRF Properties
Exceptionally high dry boiling point of 590ºF (Wet 518ºF)
Superior anti-vapor lock properties
Safe for all non-mineral oil-based disc and drum brake systems
Exclusive European formula!
Exceeds SAE 1703, ISO 4925, JIS K2233, FMVSS No. 116 DOT3 and DOT 4
Brembo LFC600
![](http://i1012.photobucket.com/albums/af250/supremedk/Brembo_LCF600.jpg)
Brembo Brakee Fluid LCF 600 Plus
Low compressibility factor at high temperature with more than 10% reduction in brake fluid compressibility at 356° F (180° C).
High dry boiling point:
Typical Competitor Racing Fluids 590° F (310° C)
Brembo Racing LCF 600 plus 601° F (316° C)
Exclusively for racing use.
Brembo Racing LCF 600 plus has been specifically formulated to provide the highest performance under all racing conditions:
•an independently proven low compressibility at high temperatures
•a typical dry boiling point of 601° F (316° C)
•a typical wet boiling point of 399° F (204° C)
It even exceeds the requirements of U.S. FMVSS 116 DOT4 specification.
Compatibility:
Compatible with all Brembo Racing Brake Systems. It can be mixed with other DOT3 and DOT4 racing brake fluids but for maximum performance advantage, before filling, other types of fluid should be drained form the brake system to avoid diluting the fluid characteristic. Brembo LCF 600 plus must not be used in Brake Systems containing magnesium parts.
Please Contact me for your Rennlist member pricing!!
Castrol SRF
Brembo LFC600
Compatibility:
