Tarett Raised Shifter Platform
Old 10-06-2012, 12:43 AM
IPguy
IPguy's Avatar
Default Tarett Raised Shifter Platform
As seen here: http://www.tarett.com/items/996-997-...std-detail.htm
Anyone used this yet?
How did the install go? Car model? Shifter? Cables?
Thanks,
Mike
Old 10-06-2012, 07:38 AM
jittsl
jittsl's Avatar
The picture you are looking at is the unit installed in my Spec Boxster. Install is a simple 4 bolt arrangement and takes half an hour at most (presuming you have no console etc.) In the Boxster (and I presume the 996) it uses stock cables and shifter.
I love it as it puts my hand literally inches from my stick.
Old 10-06-2012, 10:52 AM
sbelles
I'm in....
sbelles's Avatar
The scruits were looking for a SPB with a raised shifter at NJMP.
Old 10-06-2012, 11:00 AM
Streak
Perfect Angel
Streak's Avatar
Oooooooooo!
Is it too late to file protests for VIR?
Old 10-06-2012, 11:19 AM
IPguy
IPguy's Avatar
Any issues with shifter cable length and/or difficulty of install with respect to that?
Has anyone installed this in a 996 or a GT3 more specifically?
I have the Cup shifter and Cup cables already.
Thanks,
Mike
Old 10-06-2012, 01:12 PM
Ritter v4.0
Ritter v4.0's Avatar
DIY:
Old 10-06-2012, 02:13 PM
DHI
DHI's Avatar
not intending to hi-jack this thread, but...
what steering hub is that in picture above?
Old 10-06-2012, 03:16 PM
jrgordonsenior
jrgordonsenior's Avatar
And while we're hi-jacking.. David where'd did you get that massive, hard, throbbing shifter from. Does it come with batteries?....
Old 10-06-2012, 04:10 PM
IPguy
IPguy's Avatar
^here, here,
what other options are there for a shift **** without a boot other than the Cup ****?
Old 10-06-2012, 04:19 PM
GuyIncognito
GuyIncognito's Avatar
**** jokes!
love it.
and Ritter, I would also like to know more about that shifter setup.
Old 10-06-2012, 08:06 PM
Ritter v4.0
Ok, ignoring JRG, the raised shifter platform is just some alu barrels that shim it up.
The shifter itself my mechanic fabbed (batteries not included).
The wheel is OMP and I believe so is the hub.
Old 10-06-2012, 09:01 PM
racing916
racing916's Avatar
Steering hub....http://www.paragon-products.com/prod...qrhub_race.htm
Old 10-06-2012, 09:26 PM
winders
winders's Avatar
I am not sure if it fits, but I like this one much better:
http://rothsport-racing.com/Products...eering-Hub.htm
Scott
Old 10-06-2012, 11:34 PM
jittsl
jittsl's Avatar
Thanks,
Mike
Cables should be fine although mine does not have a hand brake so (if you do) you would have to consider weather it will still work OK. with the cables exiting the rear of the shifters few inches higher.
The console and shifter mounting are identical between a GT3 and a Boxster. I have swapped the GT3s shifter into my Boxster once so I know. Unless there is something odd about the Cup shifter and cables cannot imagine it will. Be an issue.
Old 10-06-2012, 11:37 PM
jittsl
jittsl's Avatar
[QUOTE=Streak;9896883]Oooooooooo!
Is it too late to file protests for VIR? [/
Go ahead and I'll protest the 2.7 liter motor you have installed (not that it did you any good).
Quick Reply: Tarett Raised Shifter Platform
