GT3 Splitter Blues
I always put a protractor on my ramps and can load either my GT3 or my very low 914-6 @ 10 deg without any difficulties.
I adjust with boards or hockey pucks if necessary.
Other than scraping the hell out of them, the OEMs seem to be almost indestructable.
Tom B.
Tom B.
Former Vendor
Here are the appropriate part numbers for the factory "flexible " splitters, Factory Posche
997.1, 2 options,
standard: 997 505 983 90, in stock $169.95
W/brake ducts: 997 505 983 91, in stock $175.99
997.2:
997 505 557 92 , Need to be ordered
These splitters will stand up to a lot of abuse from loading/unloading, kerbs etc without braking.
The only negative we have found is that at high speeds,170mph plus the splitter can start to deform, we have been installing supports underneath to prevent this, a very easy solution.
Gie me a shout if you are interested.
Thanks,
Derek
997.1, 2 options,
997.2:
Thanks,
Derek
Race ramps will make whatever you want. Make them as long as you need and they can split them in half so you can store/transport them easily. Surprisingly they don't charge that much more for the custom solution over their stock items.
Back the rear wheels of your tow vehicle onto Rhino ramps. It raises the front of the trailer around a foot and lowers the rear end. That may not be enough but it's an easy way get some additional clearance.
