"Forgiving" R-compound tires for DE to replace old slicks?
GT3 player par excellence
Mooty's got it mostly right. I use Nitto NT01s now, since the availability of RA1s dried up while Toyo tried to switch to the 888s.
I usually dust the RS's in the paddock. It's not as hard as you might think. Here's a woman dusting a BMW.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![](http://calcarduster.com/graphics/imgOriginalDuster.jpg)
It depends on what you want. If you want a good sticky tire, with lots of longevity, and all around good buy, I would go with the BFG G-Force R1 dot road racing tire. By far, and I mean Far superior to the Toyo RA-1 or R888 or the Nito. in terms of stick and tire life. I have raced them all.
Having endurance raced on all of those options, the RA-1 & NT-01 have better longevity than the R1. The R1 is a good tire, and 1-2 seconds a lap faster (depending on the course), but it won't go two 3 hour enduros like the RA-1 will. It is also more susceptible to flat spotting, and is a bit less forgiving to drive.
No, you're right. I believe Toyo is bringing the RA1 back (probably) because so many people were disappointed with the R888. But I use my tires for a long time, and have continued tuning my suspension to the NT01s I switched to when it was announced that the RA1 was going away. I like that the Nittos don't need to be shaved to avoid the RA1's 'shaky weekend' of initial tread wear.
Also, a two liner R1 isn't a realistic drive to and from the track tyre if that was desired. Any standing water and you're in big trouble. Possibly with insurance I'd suspect? The RA1 or NT-01 will also offer some wet weather driving on the track vs the R1.
Everyone,
I'm slightly "de-tuning" the 964 racecar I bought for DE use. While I have a year of DE experience, I don't consider myself ready for slicks yet. Maybe after another season.
Right now the car has 250/650R18 (front) and 280/650R18 (rear) Dunlop slicks mounted on BBS 18" centerlock rims. Would 265/35R18 and 295/30R18 tires be a correct DOT replacement size? Something like a Toyo R888 or Bridgestone S-02?
I run 16" Dunlop Direzza Star Specs on my 1987 Carrera ... that is really my point of reference for a high performance tire.
280/650R18 is very close to 275/35 x18
Nitto Nt01 comes in those sizes RA1 does not
OK! Thanks for all the input so far everyone. The RA1 is definitely getting a lot of recommendations along with the NT01. So those I will look at.
I attempted to measure the width of my wheels tonight -- its a bit of a challenge since tires are mounted, and there aren't size stampings on the wheels (that I've seen; maybe I didn't look closely enough at the back side). I think the fronts are 11.5" and the rears 12.5". They are 18" BBS centerlocks with magnesium centers. Does that sound correct for a 964 RSR that was converted to 993 EVO 2(ish) specs? I've inspected the centers carefully for cracks.
Edit: Bill Verburg said:
"GT2 Evo used BBS10x18ET32 & 11x18ET14, yes, they were centerlocks."
So I may have mis-measured with my tape. The tire sizes that are on the rims right now look good -- not too narrow or wide for the rims.
I have two sets of slicks at present in the size I mentioned (250/650R18 and 280/650R18), one mounted, the other not. They are both at least 6 years old. Not sure how they were stored -- likely in a garage out of direct sunlight. But I can see that the slicks that are mounted already have some cracking around the sidewall. Not tons but some.
When I have driven the car on the "street" (I have forgiving neighbors and live out in the country) it wants to pull left and right and not go in a straight line. Tie rods appear fine as do wheel bearings so I am assuming these tires are a) not heated up and b) rock hard because they are old.
like this, rubber bands can be used to hold them in place
![](https://forums.pelicanparts.com/uploads20/3_12_06_+0011343697054.jpg)
![](https://forums.pelicanparts.com/uploads20/3_12_06_+0021343697067.jpg)
![](http://members.rennlist.com/1976c38/WheelsFAQ-diagram.gif)
Most aftermarket wheels will measure 1" more from face to face than the bead width, BBS have thinner flanges and will measure ~.875" more than the bead width.
Unlikely that you have 250/280 mounted on 11.5" and 12.5" wheels. That would be too much of a stretch and as you've said, they appear to fit well. I'd take at least 1-2" off your guesstimates on the wheel width. Sounds like a nice car btw.
