Probably not the very last remake of the tow vehicle question
I'll admit it, I'm trying to be cheap here.
I need a tow vehicle and I don't want to buy one. I will have to buy a trailer, so I'm trying to save the money for that.
But GF has a truck, a 2010 Tundra 4X2 Double Cab. This would be a no brainer, but she got the 4.0L V6.
Supposedly 236hp and 266 ft-lbs. Max tow cap 4800 lbs.
Is that going to pull a fat *** '84 Carrera (it is on a diet) on an aluminum trailer?
She did not get the towing package, so what kind of hitch and connections does it need? The bumper is supposedly rated to 5000 lbs, and it already has a 4 wire trailer connector, but on a car trailer with electric brakes, it that what it needs, or more?
Any leads on a good lightweight trailer?
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
My 4Runner is rated for ~7000# and tows an open Trailex + 993 easily, I like having ~100% reserve capacity
Mr. Excitement
Been pulling trailers with a 3.3L V6 for 12 years. Set the trailer up right and you will be safer than many I see at the track with larger trucks, poor loading skills that take paddock pride in shaving 20 min of the drive in by doing 80+ while towing on 3 year old chicom trailer tires.
You will need to install an elec brake system in the truck. Kep everything in good condition, load the rig well, drive at legal speeds and have a good time at the track.
Wouldn't be ideal but IMHO it's doable. You'll need a 6-way connector (probably should have the Toyota dealer wire it up) and definitely get a brake controller. At least out your way it's pretty flat. Check out etrailer.com.
Why you need a 6-way: http://www.etrailer.com/faq-wiring.aspx
Tow hitches: http://www.ebay.com/sch/i.html?_trks...hitch&_sacat=0
One with wiring kit included: http://www.ebay.com/itm/TRAILER-HITC...#ht_3811wt_962
You'll have to do some research on that vehicle to make sure you know what you need.
Tranny cooler and air bag assist springs on the truck would be a good idea as well.
The truck should have enough power, the load and towing limit is mostly set by the suspension.
OK, thanks. I'll take the truck by the Toyota place, see how much a hitch, wiring, etc. costs and what they recommend. Maybe they will have a V8 I can talk her into buying.
The Penguin King
From your avatar can I assume you're a vet? If so then go lease a decent tow vehicle and write it off 100 % ( I won't tell). Small, underpowered, and under suspended tow vehicles are great on most days, it's that one time when a gust of wind or bump in the road sets the trailer swaying that you'll wish you'd bought a proper tow vehicle (in between praying)....
That's what really happens...
I think I will just put on a hitch, rent a U-Haul car trailer every couple of months, and run it until the transmission burns out, then talk her into buying a V8.
Yes, I'm a vet, but I work for the USDA now, so no write off. That is hard to do with a truck, unless you have a horse or cow or house call practice, and if I was still doing that, I wouldn't have enough money or time to even think about tracking.
Yer nutz.
You're planning on borrowing a vehicle with a max tow capacity of some 4,800# to haul a 2,200# steel trailer and 2,800# car, plus load for a track weekend inside the truck.
This transcends foolish on so many levels. And no, that truck is not a monster.
If this is only once each couple months, why not rent a proper rig, from front bumper all the way back?
You have only done one DE, why are you worried about a trailer now?
Spend the money on getting your 911 road ready and on track time. You shouldn't be thinking of track-only mods yet.
I drove my car to the track for 5 years until I invested in a race prepped, track-only car. If you are worried about spending money on the truck now, you are thinking backwards.
