Oil Cooler Line Sealant?
I am re-installing my front oil cooler and I need to know what type of thread sealant to use. Anybody done this successfully? What did you use?
TIA
TIA
Look into this one. Kevin recommends it for his oil line check valves over on the 993 Turbo Forum:
The sealant is Permatex Pneumatic Sealant #54550. Small amounts are applied to the fitting threads. Cure time is 10-15 minutes.
I've used that with good success.
