Need help-- Removing lower control arm spindle
Working on 997.2 C2S, front lower control arm
I have removed all the nuts/bolts that fasten the lower control arm to the frame and the wheel carrier. The spindle that sticks up vertically that is at the outboard end of the LCA will not come off or out of where it goes through the wheel carrier ((bolt is off of spindle). What's the secret?
THANKS!!!!!
THANKS!!!!!
