The Clash at The Glen - heck with block talk, trash talk!
Old 06-06-2012, 10:53 AM
  #361
bauerjab
bauerjab's Avatar
[QUOTE=Paul 996;9590249]Ok Ok, so you were back in front by start finish and get credit for leading the first lap
Interesting.... So you merely "borrowed" the lead for awhile.and thought it was actually yours when it was not. Is this a pattern?
Old 06-06-2012, 12:35 PM
  #362
dan212
dan212's Avatar
Default Broken Control Arm
OK streak.. Here you go.....
This was AFTER THE CHECKER for saturday warmup before first sprint. Broken left rear control arm. Thank GOD this happened in warmup, after the checker and not in a race or a lot of people would have been hurt. Better that it happened here. Watch to the end..
First hit was fixable. Second makes for a write off.
If you laugh at the girly sound I make, bite me
Did I mention this was after the warmup checker??
Old 06-06-2012, 12:37 PM
  #363
good hands
good hands's Avatar
Video of the year. Hands down.
Old 06-06-2012, 01:13 PM
  #364
Mike in Chi
Mike in Chi's Avatar
FARK!
Wow. Glad you're ok.
Old 06-06-2012, 01:19 PM
  #365
Streak
Perfect Angel
Streak's Avatar
Dan that vid makes my ball sack tingle. I cannot imagine just having to sit there and wait for the impact. Glad you are ok!
Old 06-06-2012, 01:40 PM
  #366
gums
gums's Avatar
Christ! Isn't there a yellow?
Old 06-06-2012, 02:31 PM
  #367
BostonDMD
BostonDMD's Avatar
Video no longer available?
Old 06-06-2012, 02:37 PM
  #368
good hands
good hands's Avatar
Still works for me
Old 06-06-2012, 02:51 PM
  #369
sbelles
I'm in....
sbelles's Avatar
Yikes!
I think that was the appropriate girly sound.
Old 06-06-2012, 03:05 PM
  #370
Paul 996
Paul 996's Avatar
Dan,
Sorry to see this. Glad you are ok. Please post a picture of the control arm that failed. At my last race I had a GT3 2 piece control arm fail up front at the short end where it attaches to the chassis. Also happened after the checker and on my way to the pits.
Best,
Paul
Old 06-06-2012, 04:47 PM
  #371
dan212
dan212's Avatar
Just bent metal and money I don't have.
Car is totaled - The last hit caused serious front end & subframe harm. But nobody got hurt. Hans, harness and Halo seat did their job.
Thats the main thing: nobody got hurt. That was all that was going through my mind at the time: please nobody get hurt because of me. If this were in a race, there would have been carnage.
I did have a pucker when the two white Cayman's appeared. Uh-Oh / WTF? The guy who clipped me was trying not to hit me head on while the other cayman was trying to pass him. I thanked him after for not killing me.. He had to be towed off as well.
AND YES - sure there were yellows, flashing lights - never mind the checker. I was also flashing my one headlight (Thats why I still had the power on) . Don't know if it was working.. But you can tell who was looking ahead and who wasn't...
The outside Cayman already has a 13 from Lime Rock. The gray Cayman that looked like it was trying to pass Hoyt after he had slowed down and missed me by a red hair? I still can't believe he didn't hit me. Husband and wife. I kid you not.
The control arm was an RSS lower control arm. Broke at the ball. Two years old, moved from my GT3 to this car a year ago. Sounds like yours failed in the same place.
I'll try to get pix.
Old 06-06-2012, 05:28 PM
  #372
analogmike
analogmike's Avatar
And they say GT3 cup drivers are bad... that gray Cayman should have his license removed, maybe the white one too.
Old 06-06-2012, 05:30 PM
  #373
cello
cello's Avatar
Thats just a nasty place to get parked too... Could not have been fun in there - a little like a tail-gunner in a B-17.
I think I'd be a bit mad about the LCA given the location of failure, age, and - now - history...
From the website:
"RSS High Performance Tarmac Series Suspension Components are designed, engineered and manufactured on location here in the USA. RSS Tarmac Series Control Arms are manufactured from 6061 aerospace grade billet aluminum. This allows for a more uniform molecular structure at every point of the arm over the cast motorsports arm giving the customer a more durable and inherently stronger part. Manufacturing from billet aluminum rather than casting results in less impurities in the metal. Completely serviceable – for the extreme, repetitive track-day participant, our high-strength steel alloy spherical bearings (with a friction reducing / longevity increasing Teflon liner) can be replaced unlike the motorsports arm, in which case the customer will have to buy a new set of arms if the spherical bearings are worn. Additionally, anodized surfaces and zinc-plated steel parts allow for better corrosion resistance against the elements. Adjustable suspension geometry – adjust dynamic camber values and roll center heights with our unique zinc-plated steel bushings. Solid monoball control arm ends offer a more responsive suspension over the factory one-piece rubber-injected control arm (also uses the same high strength steel alloy spherical bearing found in our control arm monoball kit). Unique design provides more gusseting over the motorsports arms for added strength and aesthetically appealing looks."
Old 06-06-2012, 06:03 PM
  #374
Carrera51
Carrera51's Avatar
Yikes! Glad you weren't hurt. That could have turned out a lot worse.
Old 06-06-2012, 06:05 PM
  #375
gums
gums's Avatar
As fantastic a circuit as the Glen is, those stupid blue bushes really ruin the place. Any incident at that spot can become catastrophic, as this did, because there's just no escape. And that's not the only section like that. Any other circuit and everyone would have just taken to the grass in avoidance. A real shame, and those bushes have even killed a few.
Quick Reply: The Clash at The Glen - heck with block talk, trash talk!
