Setup Help - Tires with new wing
Gurus,
I put on a big wing (Aeromotions, 65" wing) on my 996 GT3. Alignment in the rear is set at -2.4 camber and .13' toe-in. Car is running 700/900 springs. Pressures are targeting at 36-38 hot. I didn't get pyrometer readings.
I am now consistently cording inside edges of rear tires. I had a set of Eagle RS tires that died (to the cords on the inside edge) and then put on a scrub set of R6s that also corded on the insided edge. This is happening on both sides simultaneously, although the loaded tire shows a bit more wear.
Question: do I need to take some camber out with the wing now? Adjust toe? Reduce springs? Change something else?
I dig the new wing, but it's a pretty pricey experiment changing one variable and then running through a set of rears. I figured I'd ask those in the know and save some time and heartache.
Thanks!
-td
Thanks!
-td
It does sound like you're working the outside of the tires too much, but getting a pyrometer would be a much more cost effective way to diagnose tire usage than looking at what part of the tire is wearing out first. I suspect you'll find that the inside edge of the tire is significantly hotter than the outside - you'll want to reduce camber until you get the temps more even across the tire.
Agree with Mike...however, if tire life is essential, take a bit of rear camber out.
Also, don't forget with all that wing you will need to adjust front splitter to balance the car.
Here is my Set-Up.
Mainly run Nitto NT01
Alignment
Front
Camber - 3.2
Toe .2mm (OUT)
Rear
Camber - 2.8
Toe -2.5mm (IN)
Sways
Front 1 off full stiff
Rear 1 off full stiff
Moton Clubsports 14 way
Front - Spring Rate 685#
Rear - Spring Rate 913#
Also have RS Wing and Cup Splitter
Alignment
Front
Camber - 3.2
Toe .2mm (OUT)
Rear
Camber - 2.8
Toe -2.5mm (IN)
Sways
This isn't an issue of cording the inside edge first. It's cording the edge after 2 sessions. I ran through 6 rears in 1 weekend - all corded on the inside edge. None of these were sticker tires.
-td
-td
It could be that your rear toe is out of alignment. It might be a combination of camber and toe. If you floor it hard to induce wheelspin (like a dragster) you could be the source of your problem. Cording a new tire in 2 sessions is not normal. 315 wide MPS cups also used to do this because they are too wide for our stock wheels. 315 Hoosiers or other tires were not a problem. What brand, model and hot pressures are you running?
http://www.tarett.com/items/996-997-...lnk-detail.htm
if you already have `em just re-check the toe settings.
I ran a set of hooter 295s, eagle rs 315 and hooter 315. All corded inside edge rapidly. Although first set lasted 5 sessions.
Toe is .13' per side. I have tarret toe atms with locking plates. Will have aligent verified ASAP.
-td
-td
I've been surprised before... but I would be very surprised if any kind of wing could produce a sudden and noticeable change in tire wear on a production-based car. Unless you're running for long, long stretches at 160 mph, the effect on the tires is probably comparable to driving with a passenger's additional weight or running a few extra laps per session.
I suspect your alignment settings have changed. Toe the most likely.
Gurus,
Thanks!
-td
Thanks!
-td
Will you be out at TWS this weekend for NASA or next for PCA ?
If so come find me and we can discuss this.
