FS Track trailer
FS Track trailer
Anyone looking for a better way to transport your track wheels and stuff to the track.. here is a great solution. The trailer also comes with the hitch attachment that fits directly onto a 993, may also fit 996 without any drilling or holes. It using the tow hook as the main fixing point.
The trailer is located in Boston Mass, asking $375.00, negotiable .
Like they say a picture in worth a thousand words.. The following plate attaches to the car which enables the trailer to hook to. The main securing both screws into where the tow hook fits, of course you must remove the license plate first, and then there are two bolt securing to the bumperlets for added stability.
you would need to get your mechanic or an easy DIY to wire a plug to the read tail bulbs which have a quick connect to the trailer. you then tuck the wire and plug into the side of the engine bay when not in use.. its three bolts to remove the hitch plate.. its meant to be quick and painless..
