Tilton brake bias valve incompatible with ABS ?
#46
GT3 MC is 24mm bore, stock C2 is 22mm bore. So with GT3 you move more liquid, efficiently it results in slightly shorter pedal travel and much more precise modulation of brakes as you do not have to drop pedal to the floor at the end of the straight anymore. heel&toe is also simpler with it, at least for me.
GT3 is 25.4 & C2 is 23.8mm but agreed the pedal modulation is easier with the stiffer pedal/less travel.
#47
Just in the pits ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
I don't use anything other than what the gets directed there by the undertrays. Again I use the RS29 pads F & R and I swear they just don't overheat or fade. I probably should duct some air to the backs of the rotors since my rears are 2 years old and cracking. My fronts are about 1.5 years old and look great. Ducted air works quite efficiently.....
#48
997 GT3 thrue 2007 also used 25.4mm
997GT3 from 2009 used 26.99mm
the bigger the m/s wrt the slave cylinders the better pedal you get, to a point, as w/ a better pedal comes greater leg input.
the sweet spot for performance use is a ratio of slave/master ratios in the low 30 to high 20 range, in this range the ability to modulate and apply enough leg is optimized for most people, especially when a mild boost ratio is also used
this ratio for 996 GT3 was ~30.5
for early 997 GT3 ~30.6
for 2010 997GT3&RS ~27.6
late RSRs w/o boost use ~29.5 and are optimized for Pros in prime condition
#49
>>> The bigger GT3 MC actually produces less brake force at the caliper for the same amount of brake pedal pressure.
>> it certainly sounds like you have TC/ABD type behaviour/symptoms, and if your LSD is worn that wouldnt be helping either.
Porsche designates these older systems as:
ABS 5.3 (3 channel, no TC) and
ABS / TC 5.3 (4 channel w/ TC)
I dont have TC (only ABS 5.3, 3 channel in my car)
So when my rears slip, exiting a corner it applies brakes to both wheels at once...including the heavily loaded outer wheel trying to accelerate out of the corner! And it doesn't release for a while either....my logger suggests its usually a good second or more after I've unwound the wheel that the calipers release.
Notice the "T" in the rear brake line of the attached schematic. This is a single line feeding both rears. Hence the "3-channel designation. LF, RF and Rear.
ABS/TC 5.3 (4 channel) has 4 independent lines. Hence the 4-channel designation.
#50
bubble flare tool so I can make some new brake lines.
Made bubbles!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I have to work out the bias adjuster mounting location and then just bend the lines and I'm done. Hope it will be worth the effort.
#51
I picked up some M12x1 flare/brake nuts for 3/16th pipe to take care of the upsize/downsize issue with the M10 Tilton valve in the M12 lines.
Mine is ABS 5.3 4 channel w/TC, if I forget to turn it off I know it even before I have crossed the blend line to join the circuit.
#53
Bill, I'm not sure what the metric is that your using for the boost ratios, but I was going to add the Carrera boost ratio in the list for comparisons sake. My manuals list the 6 GT3 as 3.15 and the 996 not GT3s as 3.85 i.e. the Carrera uses a fair bit more vacuum boost. I've since moved to the 3.15 booster as well as the 25.4 MC and I like the pedal feel a lot more.
#54
boost ratio is the additional help provided to your leg by engine vacuum or hydro-electric pump the street GT3s certainly do use vacuum boost but most of the Cup/RSR versions do not, the race cars tend to have twin m/c with no boost and no abs. The 2005 GT3Cup was the last use of abs and vacuum boost.
#55
Those aren't boost ratios, they are the ratio of slave/master.
#56
For the record - note that this is the stuff I do in the day job (though not on Porsches).
Check out the 996 Factory Service Manual. Its at the end of the section on ABS and TC. I can do a cut & paste later if interested. I too was surprised to see the comments about moving a brake line. But they are actually quite specific about which lines.
Seems to me like there was a less-than-optimal translation from the German there.
120-130mph
Not sure what the technical term is.... perhaps "Brake Torque" ?... the force on the rotors overcoming the pad friction is greater "at speed" than at a slower pace .... I'll guess there is no real significant "downforce" so we can probably assume the cF of the tires (vertical load) is relatively constant through most of the deceleration?...
We have a term known as Specific Brake Torque - amount of brake torque, in N-m, applied per given bar of brake pressure. Not affected directly by speed, only by brake sizing, pad/lining selection, and tire diameter.
Of course, this does bring us back around to tire sizes, are they still close to stock or at least still the same proportion front/rear with respect to diameters?
Something I could certainly test. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I have some brake paint and temp labels around somewhere from my racing days.
Of course, since you have figured out the workaround, it does raise the question of just how much effort is worth putting back into it. I'm quite familiar with ABS 5.3, have worked on that (not too many still in the business have, it's such old stuff... guess I've been doing this too long! LOL Also know ESP 5.3, 8 and 9 - extremely well as usual - and played a bit with some ABD back in the 5.3 days...)
@ OZ951 - If you can tell on pit-out that you've left TCS on... but are leaving ABS on... I hope your wheel/tire diameters are also still comparable to stock (at least front/rear ratio)?
#57
Yes that is with ABS Functional, I run a 2.6% difference front-rear circumference with R-888s at 235/40R-18 & 285/30R-18. Even with a good functioning 40/60 LSD there is enough slip during that straight line acceleration to activate the TC.
#58
add up all the caliper piston areas, that is the slave #
divide the slave area by the master cylinder area, this is the slave/master ratio which is the primary determinant of pedal feel assuming that the system has been properly engineered to reduce mechanical flex to a minimum(most Porsche brakes systems are so engineered)
the slave/master ratio has varied on 911/964/993/996/997 from the high 20s to the low 40s depending on the application, the street cars tend to be at the higher end, the race and more performance oriented models cars at the lower end. High slave/master ratios have more travel, require less leg effort and feel softer, low slave/master ratios have less travel and feel harder and areergonomically are easier to modulate
boost ratios from vacuum or electro-hydraulic pump have varied from ~2.2 to 4.4, again higher boost tends to be used on street models and lower tends to be used on the more performance oriented cars. Boost merely amplifies the effort supplied by your leg, it does not modify the basic pedal feel except to the extent that less effort is required.
the race cars tend not to have any boost or abs, they also use lower slave/master ratios and twin master cylinders.
when the slave/master ratio is too high the m/c doesn't move enough fluid to service the calipers, this occurs at slave/master ratios ~51
when the slave/master ratio is too low the human leg can't push hard enough w/o assistance, it depends on the leg but high 20s is getting there
#59
I understand what you are saying, but the subject of my post was entirely different.
Edit >> that puts my MC/Slave ratio at about 36.4 due to the large rear calipers (piston sizes) I'm running. As compared to 32.4 for a stock 996 C2.
My observation of the pedal feel is that it is firmer than before I upsized the MC & downsized the booster and brake modulation at my last event with the GT3 booster & MC was easier to regulate than with the C2 booster and MC.
#60
Let me try to clear up the "higher pressure" issue again. What I'm experiencing is brake activation while exiting a tight corner. Same type of thing that happens in my BMW 330i everyday on the way to work LOL
However in my 996 I'm not supposed to have TC... which means I'm also supposed to not have ASR & ABD right?
BUT! with the ABS engaged.. I can tell you I am getting brake actuation ... as mentioned, I can heat soak the system in 3 hard laps... unplug the ABS and I can not.
I'm "all ears" as to what the issue might be. Early type of ABD in play?
Yes, I'd like to log the brake pressures ... I may be able to do temps as I cobbled together an IR sensor & mount a while back when I was going to do dynamic tire temps on my SCCA race car. That stuff should all still be in a box somewhere.
