FS: 911 racecar chassis and componets
For sale in Phoenix Arizona-1984 Patrick Motorsports built racecar chassis and racecar components. $30,000
My dad had Patrick Motorsports and myself (I used to be the sales manager at Patrick Motorsports) build a racecar for him and I to race and drive in DE events. My fathers health concerns and my change of priorities force the sale of the great chassis and components. This chassis build took over 7 months to complete and with my discount still cost over $24,000 just in labor!
I am selling this project as a full package with the including components still in the box:
-3.6 964 engine with around 100,000 miles that was removed out of a great running car, includes DME and harness
-G-50 transmission with only 500 miles from full rebuild. This transmission has a taller 1st and 2nd gear and ATB differential. Includes G-50 shifter and G-50 clutch brake pedal assembly. This is about a $10,000 transmission.
-KEP pressure plate and new throw out bearing
-Tarrett front and rear sway bars
-935 front suspension
-Bump steer kit
-RSR upper spring perch
-BILSTEIN RSR COIL OVERS front and rear
-EIBACH front and rear main and tender springs
-935 rear spring plate package
-Refurbished steering column with quick disconnect
-911 CARRERA rear trailing arms fully refreshed with wheel bearings, 72mm studs and monoball bearings
-911 CARRERA front hubs with new bearings and 72mm studs
-Front brake duct plates
-Boxster front and rear calipers and full BOXSTER to 911 brake adapter kit
-Front and rear CARRERA vented cross drilled rotors ZIMMERMANN
-FABCAR dual brake master cylinder kit
-FUEL SAFE 100 fuel cell-17 gallon
-SETRAB center and two fender oil coolers-mounts built into chassis
As you can see most items to finish this car are included in this package. This is a great opportunity to have a professional built chassis and new components at a fraction of the cost. Please PM me with and questions or photo request.
Thanks for looking,
Scott
-Bump steer kit
Thanks for looking,
Scott
I have had some questions about the included parts so I took some photos of the included new and refurbished components. I also forgot about the great used Evo 2 seats and 6-point harnesses. I also have had a few questions about the dash and the rear cage section where the suspension is tied into the cage. The torsion bar tube has been modified for the G-50 transmission.
Please let me know if anyone has any questions.
Thanks again,
Scott
Thanks again,
Scott
Now on Ebay. Have had a lot of interest but no takers. I will sell to a Pelican or rennlist member for $26,000. If it doesn't sell in the next week I will start to part it out which I will make more money on but don't want the hassle.
http://cgi.ebay.com/ebaymotors/ws/eB...m=300691389503
