Why Tide on jet fuel?
You need something to emulsify the fuel and get it off the track. Since it will not mix with water, you can't remove it well by simply washing it off. If you emulsify it first, you can then wash it away.
While they may have done experiments to determine if Tide works better than Wisk (which I doubt), it is likely simply the brand they bought at Costco to have available. Years ago when I did detergent research Tide was mainly neutral surfactants and Wisk used a lot of alkaline ingredients. I'd guess that a neutral/non-ionic detergent would be better for jet fuel than an ionic detergent. Diesel fuel is non-ionic.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Here's what I know about Tide - if you mix it with water in a fairly thick slurry, then paint on a white wall it looks normal in daylight. Under a black light, it's fluorescent and the painting glows. Unless they changed the formula since the old college days.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
