How much wheel lifiting is too much?
#46
All I know is the OP said:
"...I'm lifiting my inside wheel in lots of corners."
Please note that I said:
"Sometimes, to get the chassis balance you want, the RCD [Roll Couple Distribution] will be imbalanced enough to cause one end of the car to lift a tire off the ground in hard cornering."
If this issue is really specific to this track then of course you leave it alone. If it happens everywhere, it's a problem worth addressing.
Scott
Scott
#47
I think the solution is to just pit and drop off the passenger.
Cool action pics, though. Back in the day, when I used to Auto-X a front driver, lifting the rear was a kick.
#49
Same basic issue without a passenger.
![](http://td873.enteronline.net/GT3/CoolTrackPics/6.jpg)
![](http://td873.enteronline.net/GT3/CoolTrackPics/7.jpg)
![](http://td873.enteronline.net/GT3/CoolTrackPics/8.jpg)
-td
#50
A fast red 996 gt3 with a big cup wing and i think hoosiers at 48 hours of Sebring was 8 inch or more in the air with his right front wheel T10 and 13..
He overdrive the car but it was fun watching and he was faster then me in most corners
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
#51
great thread!!!!
Recently I have discovered a similar problem in my 928, but in my case the excessive body roll is causing the LSD to slip.....hopefully a stiffer front bar will fix my issue
However one example of 4 tires is better than 2-3 I have is this (when I was running normal R comps, not the slicks I have now)
I was chasing a friend in his 06 Z06 at Thunderhill....right at the apex of T3 (off camber right) a Honda blew its engine and oiled the track....I hit the oil with my inside tires, and the car instantly started understeering to the outside....at the last second it grabbed, but I drove off anyway....
#52
Basic Site Sponsor
Basic Site Sponsor
Received 3,236 Likes
Tell the factory that, Scott. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://ferrarichat.com/forum/showthr...=354704&page=2
Post #28, 15th pic down.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#53
Why do you have to be such an ***?
The problem may not be addressable within the rules for the class. If the only real solution is adding more grip at the rear (outside of roll couple distribution adjustment), so you can soften the front, and you can't do that, you live with what you got.
The class my car is built for has a spec tire setup. So, if I adjust my car's setup so I get the chassis balance I want, I pretty much have to deal with the roll couple distribution I end up with. If that has a front tire hanging in the air sometimes, I have to live with it.
Scott
Scott
#55
All that Scott is saying is that theoretically 4 tires on the ground is best, but that's not always possible for a number of reasons.
#56
#57
Only in the corners.
But yeah, mostly. Can't shake it. (heh, a pun!) Working on it. I don't think it really matters, it's only upsetting the chassis and reducing overall lateral Gs. No biggie to overall lap times. (j/k of course). Seriously, it's annoying as all-get-out. I'm sure smoothing out would help overall lap times. It's on the list.
IMO, the car turns-in fine. It doesn't feel like there is any fighting to get it to turn. Is there a particular part of the video that suggests an understeering/difficult car? As for setup, car is set to almost full soft in rear, and almost stiff in front. I think one off on both ends, so there is defintitely room to soften the front if necessary.
edit: I think GT3s need a little more agressive entry "suggestion" to get the car turned and set for power. And there is some hand chatter through the corner (not so much on entry like me), and I'm surely overexaggerating it anyway. I'm a work in progress for sure. I may be a complete goober, but I try to emulate this:
[ERVTX's video, not mine]
-td
-td
#58
I didn't read all the pages, so sorry if this has been suggested already ... but one way to eliminate the wheel lifing would be to add wider (or stickier) rubber at the rear. This would allow you to stiffen the rear sway or soften the front sway without upsetting the car's balance. Of course, more or stickier rubber may or may not be an option depending on what fits and tire compound availability.
Scott T.
Scott T.
#59
-td
-td
#60
Admin
How long are the new stiffer springs?
When I changed mine I had to modify the collars. I gained about 15mm of droop.
Before that, it was lifting a wheel when running over a coin.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/465121d1281154745-moton-clubsport-users-what-is-the-best-set-up-for-steet-track-use-colars.jpg)
