How much wheel lifiting is too much?
Rennlist Hoonigan
which cost no drachmas
A tire in the air cannot provide any traction. Once a tire is in the air, the axle at the opposite end of the car must deal with all the load transfer. Neither of these is a good thing.
You can't always eliminate wheel lifting, but it is best to eliminate it if you can.
Scott
Scott
I've chased this on a few cars. Most times it ends in going slower. One time it ended up with droop limiters and a trip to the wall.
I think what Scott is eluding to is the more you commit to entry speed the less you are able to mash the throttle at exit. Inside wheel lift can be exacerbated by not unwinding the wheel and or over slowing and applying heavy throttle on a later apex exit. I remember Leh Keen commenting on someones avatar depicting a ton of wheel lift and he had suggested keeping four wheels on the track as faster. You may not have much grip on an inside wheel but once off the ground you are likely to exceed the grip for the outside wheel.
Don't poo-poo my craptastic driving in this video. It's been a long time since I was on the track, without a passenger, and driving this configuration. (This was Saturday, session 2).
Best laps of the weekend were in the 1:22s, but I'm pretty sure I could creep into the 1:21s if I uncorked a flyer and didn't drove so poorly.
-td
Was the guy behind me! I dig the picture
Full carbon wrap. Car is silver.
Rennlist Hoonigan
Matt,
You can find all the photos you want showing a front inside tire in the air. That doesn't make it a setup we should strive to copy. Sometimes it is what you end up with....but it is not what you want if you can help it.
Scott
Scott
Rennlist Hoonigan
I'm not saying you should copy it or strive for it. Depending on the car, corner, etc., it may happen. Doesn't really mean anything. Trying to solve it all the time is answering the question that no one asked and will probably make you slower. I've been down that road and know where it ends.
^^ the pictures in that article typically show big variation in inside wheel lift front to rear which is obviously symptomatic of the problem the article is addressing, that ideally a car will always corner better with 4 wheels on the ground than 3. If you are getting a large amount of wheel lift at one end of the car compared to the other, it probably indicates room for improvement, but in the case of the OPs pictures that's not the case.
The rear wheel is also lifting a little, plus the corner is dropping away on the left hand side and presumably he is going to power at that point transferring more weight rearward. All adds up to a pretty normal looking picture to me and I wouldn't be worried about it indicating a setup problem unless something felt bad with the car.
With enough tire grip, most road cars with relatively high centre of gravity and suspension design limitations, even the most perfectly setup car, will reach a point where they will lift inside wheels. If you had enough grip they could eventually roll over. As long as there isn't a big imbalance between front and rear in the amount of wheel lift, it may just indicate you are reaching the physical limits of cornering force for that particular setup.
TD, based on the video (alone), I'd say leave the car alone & smooth out the driving. I am curious also how turn-in is.
FYI, there are a couple of 1:23's with a passenger in here from November 2010 on that clockwise configuration:
