AIM Solo - anyone having problems upgrading software?
#31
Basic Site Sponsor
Basic Site Sponsor
Received 3,201 Likes
This means there is nothing wrong with the ECU output. I don't believe the AiM Solo DL sends any kind of electronic "receipt confirmation" to the source of the CAN data, so it appears you've touched wires in a way to upset the vehicle ECU to instrument cluster electronics. I'd substitute another cluster and see if it comes alive.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#32
Have you removed all wires from Solo unit which you added before? does gauge cluster work with no solo wires in the system? Done; no, even after trying to clear the 'can timeout' and 'insturment cluster comms with can bus' erros with the durametric software.
ECU is working fine (it think it is like I said, but it could be working 50%, no?) you have issue with receiver from CAN bus in your instrument cluster CU. it is either fried CU in the instrument cluster (10% probability) or damaged wires/connector somewhere (90% probability - very low prob of damaged wires as I was super careful, no pulling , twisting etc.., v careful with solder)). it is just not easy to fry that CU but who knows. remove all wires you added and try car out without them.
#33
i am not 100% sure but instrument cluster replacement may be tricky and also require immobilizer replacement. but i am not sure how it is done in 996 cars and to what degree those systems are linked to each other.
