944-Spec Race Video From this weekend!
My video's from this weekend.
Saturday Jan 14-2012 - Firebird Main - Fast Config - Best Lap 1:09.9 - Full Race distance
Small Bore Race 944 Spec - Started 4th in Class 5th overall. - Video from car number 94 - Red/White Two Sisters Jewelry Boutique / Gina Marie paper designs
Hightlights - Battle with Steve Marlow White #47 early part of the race before running out of fuel at just the wrong moment. Then with Rennlister Jim Richard in the PTD Spec Boxster.
http://youtu.be/NyFeNUK9s58
Sunday Jan 15-2012 - Firebird Main - Fast Config - Best Lap 1:09.9
Small Bore Race 944 Spec - Started 3th in Class 4th overall. - Video from car number 94 - Red/White Two Sisters Jewelry Boutique / Gina Marie paper designs
Highlights - Battle with Steve Marlow again this time for the entire race duration. - Thanks to Jim for allowing Steve and I to battle.
http://youtu.be/9z4dHHJMmz0
No I don't believe they fill in the waterbox. However the transition to the rubbered up burnout area results in a change in grip. If you are running at the limit you need to plan for that. Else where you need to use the curbs to get a fast lap. Sometimes it is a bit rough when you do. One guy busted a shock when he went a little too far over a crub.
Steve did not spin when I wacked him. We we hit solid bumper to bumper resulting in a few scratches on each car and it will "buff out". What happened is that he ran out of fuel right at the moment I was a few inches behind him with me WOT at 5500 rpm in 3rd. That caused him to slow and I had no place to go. That is the risk you take when you run that close.
If I can manage to get it together in time, count me in for HPDE 3.
Joe, thanks for posting, that was fun! Tucking in behind you guys was illuminating, I haven't run the fast config in many years...had to just grow a pair and stay off the binders through concrete canyon, and the lack of a limited slip was taking some getting used to in the tower turn. Oh well just trying to stay out of your points race... Can't wait to give it another go, but missed the class racing as well...decisions decisions... Onward to Chuckwalla!...
Darren is ON FIRE! (unlike Dave, in a good way) that small block chevy he stuffed in his car really seems to be working well...
Kent, you do a nice build my friend...hopefully you get the green monster out soon, Chuckwalla open track day would be perfect for it.
See you guys soon.
See you guys soon.
these were great. I loved seeing whole races as opposed to only action clips. and walls *ugh* I hate walls. That tight section takes some cahones. In the second vid, it looked like several times you were going to get around, but just couldn't. Seemed like 1 slight mistake was the difference between gaining and loosing significant position for both drivers.
thanks for sharing. I cant wait till my next race
Very cool, thanks for sharing. Gives me extra motivation to get my Spec 944 finished.
I don't know this track, but it looks like you are having major traction issues in the tight hairpin leading onto the main straight/drag strip. The white #47 and red spec Boxster that you are battling with seem to get much better traction on exit and walk you on the straight. Do you have a limited slip? You come right up on them in the tight section right before, however, looks like a lot of fun!
Thanks Glad you liked it. I wish I had a better video editor, but this works fine. My native video format does not allow me to use most standard editors.
Yeah those walls take some getting used to, but I have been driving this track on and off for 10 years so they are just sort of ho-hum. Must be respected, but not feared. The "Tight section" was actual the the faster bit they added back in for this event. Used to run the track this way years ago and moved to a tighter bit that created a straight shot in "concrete canyon". That is area under bridge with two walls on each side. That really interupts the flow and we used to have to slow down alot. Now I just take both the left and right at the top of 3rd gear nearly flat to the floor. The left is easy flat, but the right take a lift to make sure the nose bites. The last left/right before the hard brake zone is flat in 4th.
I was faster than white car in both races in twisty bits. I do not have quite the power from my motor to keep up on the long straight however. (should have put in fresh rings when rebuilt, but did not. Oh well) Therefore I could never really try a super late brake into the final turn. If I did I would be slow down the main straight and get passed easily. What I was working on was trying to force him to make enough of a mistake defending so that he got bad run down the straight and I got a good run. If that happend I might be able to be in spot to challenge under braking for turn 1.
That happend once, but I got picked by the red Rx-7 in turn 1. I might have been able to out brake him even on the outside for turn 1 and hold there till the right harder in the canyon. I did that on lap 1 with another car, but you just can't see it in the video. Anyway that RX-7 was on the outside when we got to turn 1 and really did not want to try go 3 wide trail braking through there. Seemed like bad idea. In any event some really good racing and alot more fun to finish 3rd in fight like that than to finish 1st just lapping.
