997 Cup rotors?
997 Cup rotors?
Does anyone have a tech drawing of the rotors for a 997 Cup? Do they run 380mm x 36mm? Are they running these on 18" or 19" wheels?
Can anybody at least confirm the dimensions for the 997 Cup rotors, and what wheel sizes they run?
Thanks a bunch Clay. That gives me some hope then. Don't suppose you've got a pic or two showing them. Specifically how much space you've got between caliper and inside of rim. I'm not sure of the difference (if any?) between 996 and 997 calipers? Also, do you know what thickness your rotors are?
My rotors are 1.25" thick. Some cars with the endurance brake package had 1.5" thick rotors.
Thanks Neil. Guess I need to find out the physical dimensions of the actual caliper now.
Any leads anyone?
Any leads anyone?
1) We know the 350mm rotor will fit inside the Fikse 18" wheel.
2) Can always try to work a 380mm in there at a later date.
3) More space between rotor/caliper/wheel is a good thing for avoiding heat soak.
4) Bit less unsprung weight.
5) Bit less cost on replacement parts.
6) Car will be pretty light. Sub 1200kgs.
7) Not running Endurance events.
So basically all should be well.
Thanks Bill. As ever, you're a wealth of information.
OK - no worries.
I found some templates on Stoptech.com for their big brake kits, that also have the standard rotor sizes on - these should be easy to re-engineer for the cup caliper on the rotors you want just by cutting it differently and cutting a different template fo the caliper.
I have attatched one of the docs for the GT3 as an example.
Thanks for that. Handy doc. Saved.
