944 best wheel and tyre combo for slicks
Im just about to start the slippery slope of racing a 944 in a classic series here in Malaysia. Have never raced on slicks before (other than on a bike) so just looking for any views on best wheel and tyre combo's to consider. The car is being built from a bare shell in the UK. They run standard 16 wheelers and threaded tyres in the series in the UK but just wondering if I would have better slick options on 17s. Any advice on wheel and tyre combinations for slicks on 944 greatly appreciated
If you're running stock sized brakes and can run 15's, I'd do it - they'll be lighter and cheaper to buy tires for. 16's or 17's can also be made to work, but I'd really only go to them if you need to for more width (wider tires tend to be available for 16 or 17" rims) or if you need to clear larger brakes.
The bigger question is what width to run - you'll hear answers all over the board, but as a general rule I'd say the higher the average speed of the track the narrower you want to go, and vice versa.
Thanks for the replies... Diameter is free and widths are max 9 front rear 10. Tyres are free I.e. full slicks and wets are ok. Sepang F1 circuit is where we do all the racing and it has two long straights, about 1km each and in total is about 5.5k. Other than the straights is a fast flowing circuit. I'm leaning towards 16s but just wasn't sure how much choice of rubber there is. Budget wise I don't mind spending more money if it bring lap times down
with 10" rears you will probably want something like 275 or 285s but that will be tough to find for a 16"
also you will need 17s for big reds
sounds like a fun series.. post pics when its done!
Any restrictions on final drive ratio? If none then overall diameter is not big factor since you can re-gear to compenstate.
I run 225/50 R15 on 15x7 wheels with stock gearing. This is faster than running 225/50 R16 with stock final drive due to the smaller diameter. However since you can go 9 and 10" wide do it. I am limited by rules based on cost containment to the tire and wheels I run.
