944 Cup 2012 Rules Changes
Rules changes for 944 Cup 2012:
Safety
At a minimum, require each car be equipped with two working stock brake lights at all times and at least one operating rear stock tail light. Highly recommended is an FIA approved flashing rain light for use during wet weather track sessions.
Cup Class - Allowed Modifications
Suspension
Billet aluminum wheel hubs made by Racer’s Edge and Stuttgart Motorsports are permiited.
Body / Chassis / Interior
The 924S models can also use a 944 rear factory spoiler.
Modifications to the underside of the car for the purpose of improving aero effects are not allowed. The factory splash guard located under the engine may be used or deleted. Additionally an undertray of any alternate material may be used that extends from the front of the car back to the front edge of the front wheel opening.
Stock rear spoiler must be in place with no modification. Stock 924, 924S and 944 rear spoilers are interchangeable.
“Prep 1” Allowed Modifications
Body/Chassis/Interior
The existing factory spoiler can be extended up 6 inches. Rearward brackets or braces can be used to support the spoiler extension. The spoiler extension can be made of any material. The factory spoiler is only comprised of the rear section of the factory spoiler, and does not include the rubber trim pieces that extend up the side of the glass hatch. The rubber trim pieces can not be modified. A stock 968 spoiler or aftermarket replica can be us.
Door handles can be deleted and handle pockets in door filled
“Prep 2” Allowed Modifications
Suspension
Front control arms may be modified or replaced with updated or aftermarket control arms providing that the mounting locations remain the same as OEM and the end links are not adjustable.
Super Cup Class - Allowed Modifications.
Engine/Transmission
Lindsey Racing Red Clubgate allowed as a substitute for the stock wastegate.
Suspension/Brakes/Wheels
Body/Interior/Exterior
Aftermarket rocker panels are allowed.
Doors, engine hood, headlamp covers can be replaced with identical parts of size and shape made of non-stock materials. Gaps around the headlight covers be taped over and/or permanently filled in with body putty and/or similar materials. Fenders can be flared front and rear.
Rear wing with a single plane may be added. The maximum wing height can be no greater then level with the top of the roof. The stock spoiler and the hatch rubber side trim can be removed.
Door handles can be deleted and handle pockets in door filled .
( Exclusive of safety requirements, the above changes are also reflected in PCA SP2 and 3 rules)
Safety
Suspension
Suspension
Engine/Transmission
Dave, with regards to supercup:
1. Did you mean to say the Lindsey Racing blue clubgate? The red one is a dual port and is not approved by PCA like the blue one.
2. PCA SP3 specifies a rear single plane wing must be 9 inches below the roofline. Please clarify.
Yes, blue, not red. Change to Cup rules has been made to reflect. And, PCA is also going to change their rules for SP3 to reflect the change in the use of a wing per Cup rules.
PCA is also going to make a change that will include the 944 models for the use of aftermarket cast or forged pistons for all SP2 cars, either stock size or factory-type overbore for repair. They must maintain stock CR and displacement..
Herr Unmöglich
Looking forward to 2012... some nice developments here in the PacNW with our own dedicated class in Conference, the ability to once again run double entries, and another great new track (Ridge Motorsports Park) coming online.
