Anyone ever use a system like this? Longacre Tirelief
TIRELIEFS™ Tire Pressure Relief Valves (link)
It would be nice to 'set it and forget it'.
Relieves tire pressure buildup as you race - automatically.
Use with quick change adapters or mount directly in your wheels by drilling a 1/8" NPT thread hole.
3-40 psi range
100 mesh inlet filter - to keep dirt inside tire from plugging TIRELIEF™
Lightweight aluminum - only 9 grams - won't affect wheel balance
Pro-Team TIRELIEF™ Kit
Preset your TIRELIEFS™ BEFORE you install them in the wheels. The setting tool uses your compressed air supply to accurately simulate tire pressure to set valves precisely.
Kit includes:
6 TIRELIEF™ valves
12 wheel adapters
1 setting tool
1 inflation adapter
Carrying case
3-40 psi range
Kit includes:
6 TIRELIEF™ valves
12 wheel adapters
1 setting tool
1 inflation adapter
Carrying case
If you do a search, you'll come up with other discussions about them. I don't remember reading any examples of a user being happy with them.
You're adding weight to the stem, and you're allowing a safety item to be controlled by something that's less intelligent than yourself.
But if you try them, let us know how it works.
Addict Rennlist
Bill
OG Racing
Your Source For Motorsports Equipment
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Sparco's Largest Distributor for 28 Years
PFC Distributor for 27 Years
Pagid, Alpinestars, MOMO, OMP, Hawk, Bell, Aim, G-Force, HJC,
HANS, Arai, Simpson, Brey Krause, Longacre, CoolShirt!
Supplying Track Junkies for 34 Years.
PCA Club Racing - National Sponsor Since 1998
A Veteran Owned Business
Check out our blog!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Check out our blog!
