How often to change oil with track car?
The ONLY way to examine oil properly is through lab testing.
Let a few drops fall off the dip stick onto a white paper towel....as the oil wicks into the towel...particulates, if there are any to see will be apparent... also feel the oil.. rub some between your thumb and forefinger... if it feels slippery yet viscous you could run another day...
I know these old timer tricks will be disregarded, criticized and laughed at......Its ok.. but they are a good initial test for the state of the oil..
BS..
Visible particulates in oil is a real problem. But, if your filtration system is working well, your engine could be experiencing significant wear that would not show up on your paper towel test. In other words, if your oil passes the "paper towel" test, all you know is nothing.
The only way to manage longer drain intervals with synthetic oils is through oil analysis.
Scott
BS..
Scott
It seems to me the lab would need 2 samples; 1 before and 1 after running the car. Otherwise how relative would the analysis be?
I change mine every 2 events unless it is hot. In that case, I change it after each event. Job Gibbs VP5
Cost of 25 litres (approx 6.6 gallons) of Redline racing oil = $560 (at $85/gallon)
Cost of Blackstone analysis = $25
Regardless, the point is that an analysis is cheap compared to guessing.
Marc
Go here and look at the sample report along with the explanations of each field:
http://www.blackstone-labs.com/report-explanation.php
Scott
Rennlist Hoonigan
which cost no drachmas
