Ecoboost report
Efficiency aside, it will be interesting to see how these smaller, boosted engines hold up. I suppose that if you build them right, they should be able to withstand the stress. I have to believe that, with a trailer, those turbos are spooled up almost the entire time.
The European turbo diesels used in truck (e.g. Sprinter) and SUV platforms are generally 3.0 liters or less.
I know this is a link from Ford and their marketing department but it is interesting to watch some of the videos. According to the infomercial the wear on the engine was very little for the miles and abuse put on it. We will see what comes of the engines as they are out there on the road but everyone I spoke with love the truck.
there is a key factor that people are not discussing. The OP purchased the Max Tow Package which raises the diff ratio to 3.73 and 11,300 towing capacity. Alternatively, he could have ordered the truck with the Ecoboost and all of the towing options (integrated controller, anti-sway, etc) but without the Max package and the diff ratio would have been a 3.31 with 8200lbs of towing capacity.
The impressive fuel mileage results have all been with the 3.31 ratio (16 city / 22 highway, unloaded). If I were towing only a Trailex, this is what I would have selected if I was worrying about mileage.
Personally 10 mpg towing big trailer and 23 mpg hwy (70-80mph) is ideal. Can't get that in any gas truck these days and you can do it in newer diesels due to emissions crap. It might be possibly in smaller 4L diesel, but I have never seen one of these in truck that could carry at 10k trailer. It not just about hp and torque, but about chassis stability when towing large heavy box.
Still it seems like the F150 Ecoboost is one of the better 1/2 ton truck choices out there right now.
The OP didn't mention it so it's not likely an issue but I'm curious how Ford is keeping that little 3.5L coolled down while pulling hard for extended periods?
Well for starters, compare radiators. The F150 has always had a massive rad, and Ford was the first to actually duct (force) the air to go through the rad and not spill away around it. Then look at the waterpump, and compare it to a silverado 1500 or ram 1500. The EcoBoost trucks all have an offset front licence plate with a large air-air intercooler placed dead center in the lower bumper.
Temp wasn't a problem at all...trans temp and water temp stayed absolutely normal even after long climbs @ 80+ deg.
I replaced the LH black bumper pad where the license plate goes with a blank FX4 one, then added screens from Cloud Rider Designs and had them powder coated satin black. Nice that front plates are not required in Alberta. I'm sure the screens restrict the air flow but without them the intercooler is quite exposed...still no heating problems.
The grill is a good idea. I'm not worried about leaves and bugs getting into the intercooler but I would be extremely irritated if a rock bent a fin on it or worse.
There is no Boost gauge on any of the EcoBoost vehicles. The honeywell turbo specs indicate peak power at 12psi, and when you plug a computer into an Ecoboost OBD port, 12psi is the maximum it reads on an F150 at WOT. I have seen some aftermarket vacuum boost gauges tapped installed that spike up to 15psi, but I doubt their accuracy.
