Measurng fuel; why the switch?
Mass does not vary with temperature or any other variable, it is constant.
Cool fuel will have a higher energy/gallon than warm fuel. Underground fuel tanks will not see much temperature change with the change in ambient temperature.
However aboveground tanks, like at the Glen, do see a change with the ambient, so a fuel purchase first thing in the morning would result in more BTU/$. This would show up as more fuel in your fuel can once it warmed up.
For the hell of it I will find out the what the coefficient of thermal expansion is for gasoline to make an approximation of what the actual change would be.
Mike
Mike
Looked into the gasoline volume change with temperature. The coeffecient of thermal expansion is 0.069% per F degree. So using an assumption of a 30 F degree temperature increase (dispensed at 60 degrees and heats up to 90 degrees) and a 10 gallon fuel purchase, the change in volume is 0.2 gallons or about 26 ounces. This is a definitely a noticable change and good reason to not completely fill the fuel can.
Apparently the gasoline wholesalers buy and sell their fuel to a temperature corrected standard of 60 degrees F. When we buy it from them and it is over 60 degrees F we just get hosed.
Mike
Mike
