HANS Sport Series vs. Safety Solutions Pro Rage
I've been invited to drive in a 24 Hours of LeMons event and two ChumpCar races this summer and need to acquire a head and neck restraint system. After these races, I intend to use it for DE events in a 911 Turbo with stocks seats and factory 3 pt. belts. Are there any opinions which is the better system between the HANS Sport Series and Safety Solutions Pro Rage for these intended applications. Thanks,
Rennlist Hoonigan
which cost no drachmas
The HANS won't work with 3 point belts. I'm not sure if the Pro Rage will work with 3 point belts. The regular R3 will work with three point belts though.
Definitely the Safety Solutions R3 because it can be used with a 3 point belt. The HANS requires the use of a 5 or 6 points racing harness to work properly. And to use a racing harness, you need a rollbar or rollcage.
I have an R3 and have used it when instructing in students' cars equiped with only stock seats and 3-point belts. It seems to work fine because the system is independant of the belts.
Then again, I've never tested the effectiveness of the R3 w/ 3-point belts in an accident. (And I never hope to test it!!!)
-Z-man.
-Z-man.
In your situation I'd go for the R3 as well. I've seen a few guys instructing that use the R3 because they end up in cars with no harness and no roll bar/cage.
I tried on the R3 and the Pro Rage at US Racegear. The R3 didn't bother me when sitting in my car's stock seat. For the track I'll use a shell with a 6 point harness and roll bar. I may get the R3 in case I ever ride with a student again.
Herr Unmöglich
I have a R3 and love it. Test the HANS but couldn't get used to the feel... the R3 seemed less restrictive to me.
A good way to try it out before you buy is a rental from Charles at SafeDrives.com.
Mr. Excitement
-Z-man.
-Z-man.
From what I can see when I last looked some time ago no one has any test data on the R3 with 3 points including the makers of the R3. I have not checked the website in a while but the last time I did I recall thet were rather coy about any increased safety. Plenty of folks buy them with 3 point use in mind but seem to do so without any firm data showing an increase in safety. My guess might be they know one way or the other and for some reasons(s) are not saying.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Hybrid Pro Rage requires the harness as it ties into the lap belt connectors.
The R3 and R3 rage would be the ones that people use with a 3pt belt system. I have the CF ones in stock but can get the rage series here in a day.
I use the R3 in my car and students cars. It's comfortable and secure
It seems that the R3 is favored by the respondents. I think the Hybrid Pro Rage was introduced in the fall of 2010 which hasn't allowed a great deal of time for drivers to use and evaluate,fwiw. Does anyone know of a reason not to use the Hybrid Pro Rage system with a 3 pt. belt? It seems on the surface that it's smaller size makes it more user friendly. Test results on the Safety Solutions website seem quite favorable for the Hybrid product in general although results are scanty for the R3 product per se. Thanks for everyone's feedback! Best,
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Hybrid Pro has been around for a while longer than late last year. I use it personally and have had one for over a year. It is a fundamentally different design in the way it transfers the forces.
The R3 does as has been said has no connection to the harness. It uses the long run down the back with a chest strap to keep the head/helmet in concert with the body.
The Hybrid Pro that sits up at the top of the back has straps that come down around the body and link into the lap belt connection of the 5-7pt harness. The chest strap is used only to hold the device in place while you get in and out of the car.
IMO vision on both is pretty much the same, they both have the sliding tethers. There is a different 'feel' to each one but the second I'm on course the differences go away.
I use an R3 for instructing. It's easy.
One thing you should know: safety solutions was recently purchased by simpson, and they appear to be "in between" owners. I called them a half dozen times with a technical question earlier this winter and never received a call back. Kind of stinks that they're not currently offering customer service for their installed product base and would make me think twice before laying out most of $1000 for a new device.
