Cage time for the 928
#31
Updates:
Cage is finally donzo and completely welded up. Also welded on some 1/4" steel plates to mount the spoiler uprights and almost finished the lexan hatch. Spoiler will easily hold my weight and is fully adjustable...not bad for a $50 craigslist snag. Originally had the rear mounts on the bumper but was way too flexible even with a large backing plate. Pics are below (front ride hight is set very high so I can get out of the driveway without taking out the radiator) questions/advice/comments are appreciated as always
Time for beer!
Front Frame Brace
Time for beer!
Front Frame Brace
#32
your getting there......your rear wing looks set VERY aggressive.... probably overkill until you have a splitter to match up front......it will make the car understeer like crazy in the higher speed corners....
928's are "understeering" car my nature...but you can get them very neutral through suspension settings & alignment....but my car doesn't have aero either......
#33
it was set that way just to make sure it would have enough rake for tighter tracks and was planning on making a splitter as soon as the interior is painted up.
With 2 deg of camber, 850lb front/650lb rear springs, and the 928 spec. sways set to full stiff, I found the car very tail happy. But that was with DOT 285s on the rear, so Ill get back to you once I throw the larger hohos on
Any particular reason you havent put any aero on the estate? Plywood splitters are only like 40$ in materials
#34
Seb,
Looking good man! One of the first things that stands out is you are going to have problems with that lexan if you have it mounted solidly without accounting for expansion/contraction. Did you drill the holes larger than the bolts, are the bolts tightened down completely, and is the size of the lexan the exact size of the rear hatch or is there a buffer? Lexan expands and contracts quite a bit, and if it is not allowed to do so, it WILL crack--trust me.
#35
Main hoop diagonal is supposed to be one bar. You will probably get some grief from NASA tech. I know they have let cars in with the diagonal like that, so hopefully you will be OK.
Nice fabricating, good luck.
#36
Then again with the type of power you have its EASY to add oversteer wherever you want!! :>) Its hard with my brute 200whp!!!
#37
I used rivets, so yes
There is about a 1/8" space between the lexan and the edge of the hatch plus a bunch of RTV sealant to prevent leakage... it will be fine for the summer but I'll be interested to see what happens when winter comes around
materials
No good excuse really...but I am getting a pre built by another 928er plywood splitter soon...... While my Estate rear end is not great in terms of drag...it does appear to make good downforce.....I think my next test will be how the car performs with NOTHING back there....once I cut off the estate anyway
