Heat Cycling Hoosier R6 Tires?
I also have seen no appreciable improvement in longevity due to heat cycling. However, I do get close to 20 heat cycles on a set, but I do drive them until they cord. With a good setup, the wear is even - and even with an agressive setup, you can flip the tires. WRT cycles: the first 2-3 are fasest, the next 10-12 are pretty close to equal, and the last few are a mixed bag ending with sessions that are 1-2 seconds slower, and more difficult to drive.
IMO you can run fast lap times on the leading side of the Hoosier's slip angle range and preserve a few extra decent sessions. Ymmv.
-td
This has been my experience also.
-td
I know that Hoosier reccommends heat cycling the R6 tires, but I'm curious who is and who is not. If your are, do you think you are getting additional heat cycles out of them and if so how many extra? Also, if you are heat cycling, are you having them done by Tire Rack ( or similar supplier ) or the "old fashion way" on track. Thanks in advance for any input the group can provide.
Thx.
Mick
Thx.
Mick
Professional Racing and Driving Coach
