JIC install tips and tricks on a 993 (Xpost)
I have the most excellent InTheAir suspension DIY in hand. Not replacing the sways so should be a little easier. Replacing PSS-9s, so I should have a good starting point to set the ride height.
Already posted and discovered there is a slight change in the recent run of JIC coilovers, so that's put to rest. I plan on having the mechanic do the align, corner balance, inspection I didn't screw anything up.
So, Q is, any JIC specific install tips, lessons learned, etc. anyone cares to share. I've searched a bunch, but found nothing specific on the JICs.
