Square set up?
#31
From Hoosier sizing spec sheet:
225 50 15 wheel width range 6" - 8" and tread width of 8.8" (23.8" dia)
225 45 15 wheel width range 7 - 8.5" and tread width of 9" (22.9" dia)
So in Astroman Jack's example mounting 225 50 on 15 x 9" rear must not make any difference in spite of Hoosier specification for maximum wheel width of 8" ???
Hupfer knows what he's doing, obviously.
Also, don't forget that Mark, Fred, myself, and others are driving 911SCs which have a higher rev limit than an 84-89 car. This may or may not be a hinderance at the tracks you run. My light is set at 6800 in the above video, but I regularly exceed that.
Here is a picture comparing a 245/40 x 17 on an 8" CCW to a 225/45 x 15 on an 8" Fuch.
#36
Perfect Angel
Thanks Chris. I've never been to RA so it's hard to compare. The back straights at WG and VIR would be my frames of reference. Summit is too short to be an issue. At WG I'm in 5th soon after coming out of the esses so that may be a concern and at VIR that back straight, though you start it much slower than WG, is so long I'd be concerned there as well.
Any thoughts?
Any thoughts?
#37
Any thoughts?
Any thoughts?
The WG straight is mostly uphill, no? It looks like Fred hits about 6200 in 5th.
Can't help you with VIR, never been there. Is the straight there any longer than WG or RA?
#38
Any thoughts?
Any thoughts?
#40
I tested him the lap before... so that slight bobble was just the right sort of opening i needed. Then i had to block him for 1 full lap because he was faster down the straights as you saw. Then he blew up his clutch.
#45
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
