Square set up?
Go check Mark Hupfer's car at Sebring. You should feel better about your tire choices.
The car: 1986 911 E Stock
The problem: Like a true moron I didn't do enough research and have purchased a set of 7 and 8x15 Fuchs. Only after did I discover that the best tire choice is not available. That being a 275/35. I had been told that a 275 will fit but I'm leery.
So here's the question: Is it crazy to run a square set up? I currently run 225 front and 245 rear on 16's. When I compare the 225 to the 245 the true difference in width is very very small. Hoo 225's are either very wide or the 245's are narrow. My thought is that if I run 225's front and rear I'm giving up minimal contact patch. The other option is to run 205's up front.
Bottom line: Is square a bad idea? Does a 275 really fit a 8x15 Fuch?
Keep the abuse to a minimum please![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
It all depends on the work travel schedule. I just need to mount up the tires.
I do like how the car feels on the 16s much better than with the heavy 17s it had on it before. The time sheets will tell if it is truly faster.
I'll make it easy for them: At least at Road America, MH uses 225/45/15s in the front on 8" wheels and 225/50/15s in the rear on 9" wheels.
Basic Site Sponsor
Basic Site Sponsor
Good point. He gets that Euro SC around unbelieveable fast on what most feel are undersized tires.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
From Hoosier sizing spec sheet:
225 50 15 wheel width range 6" - 8" and tread width of 8.8" (23.8" dia)
225 45 15 wheel width range 7 - 8.5" and tread width of 9" (22.9" dia)
So in Astroman Jack's example mounting 225 50 on 15 x 9" rear must not make any difference in spite of Hoosier specification for maximum wheel width of 8" ???
Hupfer knows what he's doing, obviously.
Here is another bit of confusing info: Oddly, the 225/45/15 on a 8" wheel is essentially the same width as a 245/40/17 on a 8" wheel. Chris M. and I did a side by side comparison... it was surprising. So, anyone using the 225/45/15 in the front (on an 8", not a 7") is losing nothing to the popular 245/40/17.
