New Pagid pads, RS-14 VS RS-15 ???
I'm about to change brake pads on my 993, I have had several sets of pagid RS14 Black, and these pads have been working very well for me. However, pagid has resently come out with a higher friction RS-15 Gray.
ARE THERE ANYONE WITH ANY EXPERIENCE OR COMMENTS ON THESE?
*Pros
*Cons
*Comments
See description from Pagid:
RS-14-Black - This is a high friction value ceramic compound with very good modulation, high fade resistance, low heat conductivity, and a good wear rate up to a constant temperature of 650 degrees Celsius (1202 degrees Fahrenheit). It is kind on discs, (with visible grooving, but no tendency to crack discs). Applications: Super Touring, WSC, Trans Am, and Rallye.
RS-15 Gray - Very high torque compound. It combines a 20% higher friction value than the RS14 with a slightly increased pad wear. Needs finesse to avoid over braking the car. Good release characteristic. Although the RS15 has a very good modulation (controllability) it might have an excessive bite for some applications, as lightweight cars or cars with boosted brakes.
*Pros
*Cons
*Comments
I use the Rs-14s too. I'd say if you're happy with the 14s, stick with 'em. They are already pretty high torque. Last thing you need is a pad that wears out faster and is more difficult to modulate, especially if your car is still relatively softly sprung & heavy (meaning that managing weight transfer is really important). I don't know if that applies to your car, but those are my 2 cents. I'llbe sticking with the 14's.
Blacks are high temp, high torque, and lockup too easily if unfamiliar with their power.
What exactly does "good release characteristics" mean?
The 15's really should not be used on your car unless you are a Pro level race driver or have the skill to take advantage of the Higher Torgue... Many people will over brake with them!
Stick with the 14's.
Asked about going from Black to Gray some years ago. No one answered that they had done it on a p-car.
https://rennlist.com/forums/showthre...ferrerid=15894
I ended up running Hawk DTC70s which feel like a higher torque pad than the pagid blacks. Unless you use a lot of finese with the brakes and do a lot of modulation, I dont think there would be issue with trying the Grays for a little more bite.
The RS14s are great pads. Sounds like you are happy with them, so I wouldn't fix what isn't broken. The RS15 on a car with boosted brakes will be tricky to modulate. I know one person who has used them and it was on a B5 Audi S4, that was stripped down higher than stock HP and he had removed the brake booster and ABS. You wouldn't have known it based on the way the RS15s slowed the car.
I use the Blacks as well. They sure do groove the stock rotors and I dont find them overly hard to modulate. OP: If you try the new pads be sure to post up your impressions. I dont need anything further or better but would like to hear your impressions..
OT for sure, but I wonder how that car braked 'feel' wise. My B5 S4 Avant's brakes are on-off switches. Love the car, always hated the brakes. Keep it around as its so much fun to drive on 55-65mph SL roads..
He had pulled the stock front calipers and put on Brembos that took the Ferrari F40/F50 pad and larger rotors on the front. The stock calipers would cook 4 little pads that the stock calipers took. I don't remember why, but he pulled the booster and the ABS.
Former Vendor
*Pros
*Cons
*Comments
*Pros
*Cons
*Comments
We have found that there are to significant factors to consider when going to a very high torque compound such as the RS-15 gray. Those factors are the weight of the car and the tires being used. More specifically, the car should weigh over 3000 pounds and be riding on racing slicks before you upgrade to gray. I'm afraid anything short of that combination could cause you Excess bite.
Chuck
Thanks guys! My 993 weighs 2,700 lbs (plus driver), and I'm riding on Toyo R888 tires, and I understand the RS-15 may over-brake the car. So I will stick to the well proven RS-14. I also do occational week end rides, and the RS-15 would be an overkill here.
