FS 911 3.5L Big Bore Kit Based on a 3.2L setup
Hi,
I have this setup. It includes
Big Bore Pistons and Cylinders
Heads
Engine Case
This setup is based on a 3.2L Carrera motor. The case has the spigots enlarged so that the cylinders could be overbored to the 100mm size.
The cylinders are fire ringed to the heads to prevent any loss of compression between the cylinder and head.
The pistons are 11.3:1 compression.
The parts are all in good condition. They are as removed from the motor. No cleaning or rebuild has been done to any of this.
The engine case has some of the ear that holds the alternator/fan assembly ground off. It will not have any effect on the function of the motor.
This is a great deal. You would pay between 2 to 3 times as much as I am looking for to do this yourself plus you would need to have the core parts. The stock parts in similar condition would fetch $2000 alone. In fact, if you have a 3.2L motor and would like to upgrade to these parts, I would give you $2000 in value for your stock parts toward this kit.
Also, you could always have a set of low compression pistons made and have a great 3.5L turbo motor too.
I am looking for $3350 plus shipping for it all.
Ed
Heads
Engine Case
Ed
