Successful SmartyCam To ECU Install?
Does anyone know of a successful true PnP SmartyCam to ECU install?
I ran the S/C for a few weeks, and while I really liked the video and data overlay, I could not make it work with the ODB2 setup; I am thinking a direct connection would be easier and have other benefits.
Having said that, I want to know if anyone else has had good luck with this type of install.
![](http://www.smartycam.com/bitmap/connessioni/schema_ecu-bridge_1.gif)
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Scott- FC-Racer on here has done an ECU connection with an EVO4 dash. While it's not a SmartyCam he still had the CAN connection setup run for his car and can give you his personal feedback.
https://rennlist.com/forums/members/3667-fc-racer.html
I believe his car was a 997 instead of a 6 though.
IIRC the difference in channels between the OBD and ECU connection were negligible but you can hide the wires a little bit better as you don't have to have the OBD plug in the car.
Thanks Joe.
I misspoke about the PnP nature of the ECU install as well. It looks like its splicing in 2 wires; CAN+ and CAN- from the ECU bridge, to a couple of wires on an ECU bundle.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yeah, I didn't even notice the PnP part, I just saw ECU and thought you were talking about the 2 wire splice. fc-racer I think has a real nice set of pictures showing how his is done. He started off wanting the OBD but then the simplicity and extra channels lured him into the direct connection.
Hey guys,
I was was just reading fc-racer's write up about his AIM system.
AIM install
Also found this along the way. It was interesting to me since I didn't know how to get at the ECU
http://sharkwerks.com/porsche/technical-articles/187-ecu-removal-and-installation-for-996-997-turbo-carrera-carrera-s-gt2-and-gt3.html] ECU removal
Cheers,
Adam
AIM install
Cheers,
Adam
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
We had some issues that I never had a chance to work out on Scott's car as to why it wouldn't talk to the car.
But in a matter of 5 minutes I had the OBD setup working on my wife's Mini Cooper when it first came out. Some have taken a bit more time but it's generally a plug n play setup.
Follow up: I got it working this weekend; tapped the CAN lines on the ECU and a switched source for auto start-up.
Maybe the OBD2 port should have worked, but it didn''t for me. This does.
CAN is the way to go! Glad you got it working.
I have the OBDII version and had difficulty getting it setup too. My solution was picking "OBDII BETA" when mapping the OBDII channels during setup. A typical setup would have you pick your car's ECU from a drop down menu. This setup would not work for me, so I choose "OBDII BETA" from the ECU drop down menu and was able to pick up "some" channels; rpm & throttle position. I can't get oil pressure, temp and gear. The CAN is a more time consuming and permanent install but you can monitor more channels.
odb2 adapter requires some minor setup to be done and assignments of ecu channels to aim channels but after that - all that stuff works fine, i run it when i need it and then disconnect completely and remove. camera is mounted on the windshield. quite convenient tool for my purposes.
