What does " I drive flat out" mean?.....
#31
we just spent my whole future 997 gt3rs reserve funds on an investment property we don`t need, thanks to my wife, so, i need some damage control to perform now and get used to be poor again, for a while.
#32
Super Moderator
Needs More Cowbell
Needs More Cowbell
#33
autox is totally different... only took 15 more pages to figure out you were really talking about that...
-Still those spins you served up, looked like not looking ahead... which is bad bad bad on a race course (and autox too)
its slow today..... can we push this puppy a few more pages?
how about posting up some more autox videos?
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#34
Still plays with cars.
'Flat out" - A 32 A gal driving topless?
#36
Maybe its your engrish skills, but in the Original thread, it sounded like you were talking about spinning on a race track.
how about posting up some more autox videos?![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
well, to speak about the topic... it is difficult to rationalize all that and discuss as what really happens there is pretty much a split second decision - not looking ahead is a correct generic assessment of course as all the rest is just a consequence of it, typically, and as of 'looking ahead' we speak of seeing the cones, removing meaningless cones from important ones, visualizing the best fastest line and then following that line, _properly_. go too wide and safe and you loose seconds, go to sharp and you loose again as course corrections eat up too much time, when competing with other folks over time it is all about the line, it is funny to see all the different cars with totally different power - like 3.2 boxster and gt3rs but surprisingly very close to each other compared to FTD.
So, all nice basic simple stuff above, almost all of it fits in a single sentence.
so then you just get yourself into wrong situation and need to figure out how not to go off course and may be sacrifice half of sec here but to save the whole run - and typically overdone correction results in a spin.
that was another thing i was talking about earlier - how previous sequences of hard braking/acceleration affects next subsequent corners. at track tires warm up from inside out - at auto-x it is generally reversed from out-inside, so tires and tire temperatures are indeed a big factor. in that spin run my rear pressure went to 43psi from previously stable 39psi and i could feel that difference. totally different topic is what to do after you feel it, but, well, i am not about that yet.
all that crap of learning to drive car at 10/10 at the edge of where is looses grip is quite fun, combined with not running proper line - even more fun. what is the heck of a difficult task is to do a correct assessment where do you want to go safe and wide and where you need to push beyond as it can result in a bit better total time.
track event with controlled predictable accurate motions is indeed a bit something else but it does teach a lot about momentum preservation and it is really cool thing to learn. plus one needs to learn how to shift.
i just hope i will have time and dedication to go over that learning curve, i wish those tracks would be closer to me as it is quite a PITA to drive so far back and forth, well, by my standards.
#41
in reality it was a bit little bit more complex as in addition
to not 'looking ahead' properly (and that is where i have no clue how much time it will take - to 'see' proper line right based on several key cones only) and assessing proper line i really tried to find fastest way around that sequence and first spin was a direct result of deliberate moving starting braking point way way too far into corner. sort of similar to what folks were saying here - to be real fast you need to go fast in and faster out. easier to be said than done.
I thought that Auto-X was like a slow track with no grass and guard rails on each side... stop and go type of driving but still using the same basic skills
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Anyway that looks like a pretty Flat Out driving...
#42
Could someone with real Auto-X knowledge explain what the hell he is talking about ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I thought that Auto-X was like a slow track with no grass and guard rails on each side... stop and go type of driving but still using the same basic skills![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#43
![](http://i38.tinypic.com/rjp7k7.jpg)
#44
any car driving uses same exact set of basic skills - you use your hands to turn typically roundly shaped object ahead of you, sporadically jerk your legs to press at some odd shaped metal objects down below and occasionally look around to check where your car with you inside is actually moving, then optionally most advanced folks develop tendency to think why it did not really seemed to go where it was intended to be driven. purely optional, of course, but it is all fun nevertheless, even if this optional stuff is skipped for simplicity.
#45
