Technical question: thread size on coilovers
Hey, I know this is a way out there question, but does anyone know if all the major coilover companies use the same thread pattern for their coilover collars?
I'm trying to make something work for a customer but before I order the parts I want to know they'll fit.
He has JIC coilovers and the collar/swaybar link mounting point has only been tested with PSS9/10 and Motons.
Any thoughs? I'm pretty sure the diameter is the same as they both need to fit the bore of the hubs but I want to make sure the thread pitch is the same to save turning this already ugly situation any worse.
Thanks!
Thanks!
Okay, so I have discovered that PSS10 is actually different than PSS9 threads.
PSS9, Moton, JRZ all share the same pitch.
Anyone have a set of JICs?
