Rear end wiggles under hard braking
Initial thoughts:
More toe in in the rear? Currently at 3 mm
Increase compression in the front?
Increase spring rate overall? Currently at 500 lbs
Putting an LSD in over the winter so that'll help alot, just wondering if there is a temporary solution to help.
Add rear rebound.
And the LSD.
Or just give her rear end a nice slap.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Professional Racing and Driving Coach
And the LSD.
I'm not nearly the driver VR is but my last instructor helped me with this problem in a 150mph braking zone. He had me braking hard initially and them slowly easing back on the brakes as I approached the turn in point. This easing back off the brakes took some of the weight transfer off the fronts and it helped settle the back end thus eliminating the wiggle.
Moderator
This is a question for the people that set up your car - too many variables. I spent about a month trying to figure out the rear end braking hop / wiggle when I went to Damptronics + H&R Sways on my 07 C2S. In the end, the senior engineer at Bilstein in CA suggested I was asking too much from a street oriented suspension and that I should go back to stock PASM / sways. Reverted and everything calmed down again. Often it's hard to mix and match and remain as balanced as the factory made the car in the first place. I'll say this about Gen 2 SPASM, they really did nail it this time.
Lifetime Rennlist Member
Don't you mean reducing (softening) the rebound in the rear? I know that some people say "more rebound" when they mean a more free rebound response. He needs the rear to drop quicker and make firm contact with the track. In my jargon, that is reducing rear rebound.
Basic Site Sponsor
Basic Site Sponsor
For those who do not agree, think about it this way - if you are tightening the rebound to hold the body down, what is holding the tires down?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Less rear rebound damping force would allow the rear tires to stay on the pavement with more pressure than stiffer/increased rebound. More front bound compression force would be my choice unless the track is too rough for it. Either more front bump or less rear rebound could work but you'd need to test to see which is the best overall for the circuit.
Great info so far. The track is brand new and really smooth. I'm going to increase front compression for the next day and see how it feels.
I'm not 100% sure the rebound adjusters are working correctly as there is a problem with the detent on te adjusters. I'm going to have them rebuilt this winter.
Initially TPC recommended setting 5 all around but 7 for rebound in the rear. I'm going to drop rebound 1 all around and increase compression 1 all around for the track and see how it feels.
The LSD will help. My Carrera and a fixed tail and LSD, the 964 doesn't have either. The Carrera's rear is much more stable under hard braking. I am guessing that the tail reduces lift at the rear end more than the retractable tail element on the 964, and coupled together with the LSD, make the Carrera's rear end much more stable under hard braking at the end of long straightaways, like the back and front straights at VIR and the front straight at SP and WG. Does your retractable tail retract when you go below 80mph even though the car is still moving. The 964s stays deployed until the car comes to a stop.
I don't have adjustable shocks in either car so I am no help there.
In general, I feel you are better off adjusting on the end that is causing the problem so I would start with adjustments at the rear. There are exceptions, but it needs far more than an internet post to understand if that is appropriate. That is my opinion, but it is backed by pretty much every race engineer that I have talked to or read.
You could lower the rear rebound to improve tire contact pressure for stability but then you'd have more rear body lift under braking, meaning increased weight transfer to the front, defeating the intended goal.
The only way to know is to test, as I originally said. Increasing front bound force keeps the front from diving and the rear rebound keeps the rear from lifting so the overall effect is a more stable platform that doesn't pitch excessively under braking.
You can often achieve a desired objective via several methods but the secret is finding the best combination for the car/track/driver. The only means to know what works best is to test.
Basic Site Sponsor
Basic Site Sponsor
Maybe knowing exactly when (in the phase of braking) the back of the car "wiggles" would help to narrow in on possible solutions.
