Racepak IQ3 on 964
The 964 does not have a real throttle position sensor. There are two microswitches, one for WOT and one for idle [butterfly closed]. The only way is to add an position sensor. Best bets are s string pot sensor on the pedal or a simple linear potentiometer on the butterfly shaft.
I briefly looked at grafting a 951 tps onto the 964, but it was not a straightforward solution.
You might want to look on the right hand side of the throttle body some 964 do have a pot rather than a idle/wot switches, I'm not sure what it was for as I have one that came off an unknown donor. Cruse control? Don't know about the range tho, if you find you have a pot let me know and I can throw a meter on the one I have here in a box...
