FS 901 5-sp race box w/close ratio gears
For sale 901 5-sp race box
w/close ratio gears.
Modified Magnesium Case
small crack was fixed, NOT affecting performance (see pictures)
Set up for gear oil cooling:
temperature sensor
temperature switch
AN-16 fitting case splashing the Ring & Pinion
AN-16 fitting case suction
removed speed drive
Solid trans mounts
4 bolt flanges
custom made reinforced clutch cable bracket on the side cover
modified clutch fork pivot
Billet alum intermediate plate
7:31 Ring & Pinion
ZF Limited Slip Differential 80/20
904 mainshaft w/removable first gear (needs some work)
Max speed at 7700 RPM (w/24.5” tire)
Gears: Ratio RPM Drop Max Speed
1st 17:34 (E) removable 2.0 0 63.4
2nd 21:31 (J) drilled PHII 1.48 1912 85.8
3rd 23:28 (O) 1.22 1280 104.1
4th 25:26 (S) 1.04 1064 121.9
5th 27:25 (V) 0.93 801 136.9
Four PUCK race clutch and pressure plate
As a package deal $2975.00 plus shipping
Mike
lipamax@comcast.net
temperature sensor
temperature switch
removed speed drive
Solid trans mounts
4 bolt flanges
7:31 Ring & Pinion
Mike
lipamax@comcast.net
