AIM track map sources?
Can someone suggest sources of AIM track maps? I am specifically looking for Tremblant, Watkins Glen, Lime Rock, VIR, and New Jersey (both tracks) if possible.
These are user generated, I assume.
Gary R tells me I need them.
Thanks in advance.
Thanks in advance.
I have the Glen, can email it... send a PM
Used to have a webpage with some on, but didn't keep it online...
Rick - You don't "need" them, your system will create one on your first lap of the track once you set a start/finish beacon. IF you have them beforehand you can import and play with them in GPS Manager and Google Earth, set up Splits, etc. Sorry if I wasn't clear.
No reason to be sorry; I am, umm, weak when it comes to data, so its good to get tips.
I know with my original GPS we set start/finish at the track and created track maps. The same with Smarty GPS I expect.
I wonder if those start/finish data will stick with the MXL or whether they left with the GPS module (I think the latter, as if I recall correctly the GPS module contained the memory and some processing power). Easy enough to set new, though.
I hadn't looked at the Google Earth function, though, and certainly a long way from using splits.
That time will come, though.
Thanks again for thetip.
