Watkins Glen Club Race
Any Clash racers need a set of track wheels/tires? I will be working Tech on Friday at the Clash, so I can deliver right to the track. No shipping. $1500.
Fronts:
17×8, 52mm offset, 19 lbs.
245/45/17 Hoosier R6 tires
Rears:
17×9.5, 55mm offset, 20 lbs.
255/45/17 Hoosier R6 tires
The Hoosier tires were purchased new in 2009 and have 6 heat cycles on them (2 practice, 2 qualifying, 2 sprints). Even wear and tons of rubber remains, no flat spots, heated indoor storage.
The wheels fit late offset (1987+) 944 variants, and some of those funky 911-type cars but I have no idea which ones.
Fronts:
Rears:
Underdog?
Yeah right! Pete said the new timing system had no H drivers hence the rear placement. I started 69 and finished 12 so maybe that will earn me a hard charger spot! See you at the Glen Carlos.
Enduro
You started in the number 80 grid spot and I started next to you in 81 that is correct. But when you look at the race results and add all of the racers including those with a DNF, there were 69 racers. I might have been 68 actually because you may recall Gomez blew by us in lap 1.
If anyone sees those pop up Nationwide ads on Rennlist, click my link instead so I get the business!
www.nationwide.com/alexbell
