Will these Nitto NT-01 wider tires work in my 996 C4S
After a 5 year hiatus, I am getting back into DE this year. I will start with one of the Mid-Ohio events in May.
My C4S takes 225/40-18 and 295/30-18. I used the 235/40 and 295/30 Pirelli Corsa's before. Now, I want to get the Nitto NT-01. I have to get the 315/30's for the rear, but my car under steered heavily until I put the corsa's (more grip and wider in the front helped). So, now with the wider 315's in the rear I'll have to go even wider in the front. So, I am picking the 245/40's for the front.
The tire specs for the 245/40 and 315/30 says my rim size is fine for that size. So, I should be fine with this, right?
Also, any advice on cold/hot tire pressures is greatly appreciated. The last time I ran in Mid-ohio there were concrete strips which were helpful in figuring out the lines, and I don't see any of that in recent video's. I am relying on the instructor to show me the ropes, but any input in this regard is greatly appreciated.
Thank you
Thank you
Did you do any searches in the 996 forum re: 245s? I think I read that they will rub. I managed the understeer on my 04 C4S with stock sizes at the track going into the corners a little slower and getting on the throttle sooner, FWIW. Nice to heard about other C4Ss at the track!
GL
I know the 996TT is a different animal, but sticking with OEM sizes/geometry (MPSC's, R888's) I really got rid of the understeer by replacing the sways for GMG Racings adjustable sways and stiffening up the rear in relationship to the front.
