996 race car ABS issues
#107
I'll try to answer that seriously because I take it as a serious question.
The new 997 Cup Cars use dual manual master cylinders with a bias bar for braking. That setup is a purist setup and also very effective under skilled feet. This solution means NO ABS -- you eliminate the ABS controller entirely. But in the grand scheme of things people will argue that not having ABS is just as fast but it will obviously increase the number of flat spotted tires.
In my personal opinion, going the speeds I go with my 996 and using ABS ESPECIALLY during trail braking in decreasing radius turns, I want the ABS!
The low-buck option is clearly dual manual masters and learn how to be a better driver. If you want ABS, that is what this thread is about.
#109
Right. Thanks Darren. I though the implication was to run the Tilton setup in conjunction with the ABS and that's why I asked my question. I tend to agree on the ABS choice. I'd rather have it than not. Therefore my question still stands.
What system (short of the Bosch Motorsport one) would / could one use on a project car?
#110
Patrick, you can run the Tilton dual master cylinder setup in conjunction with the ABS. It will be better than having a proportioning valve (regardless of whether or not it is adjustable) and will be more flexible than using a "balanced" set of front & rear calipers.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#114
#115
First you have to size the master cylinders for your application. Tilton will help you do this and get you close. Then you have an adjustable bias bar on the pedal assembly which you use to further fine tune the distribution. On my Acura installation I also used a limiting valve (don't call it a bias valve) like Vaughn pictured above that runs to the rear brakes. I use the limiting valve for quick adjustments.
As far as dialing it in you have to see which brakes lock up first. You want the fronts to lock up first because when the rears lock up first that's a great way to spin.
In the rain you can dial in a little more rear brakes because you don't get the same weight transfer to the front of the car.
Properly done this type of setup is very adjustable. It's the way Real Men drive! I'm a girl though I want ABS
#117
Also please note that some of the 997 Cup guys are retro fitting a 996 Cup ABS unit to their cars... mmmmm!
Darren, you need to fill me in where we left off, I have an older 996 Cup ABS unit, think we last spoke regards the wiring?... I'm heading to SPA at the moment and then onto Nurburgring, will be another week before I return, need to catch up.
#118
Cost ? Figure $7500.00 +/- depending on what you have to start with and what your needs are. There are a few sources for it if interested PM me for more details and even to arrange getting it installed in your car.
#120
I guess my first thought would be do you really need it ? Are you experiencing "black ice" feeling ? If you have to ask what that is then you are probably not experiencing it.
Running slicks or equally sticky tires ?
Does the race group you run with allow alternate systems ?
Do you drive very bumpy tracks ?
If you answer is yes to all or most of those then the alternate ABS system is for you, figure out a way to pay for it and make it happen, you won't regret it. There are people down under that can install it and it's no problem to get it shipped to you.
